2.3 Cold Startup Problem
Old 09-23-2004, 10:37 PM
Jimmy0306's Avatar
Jimmy0306
Jimmy0306 is offline
When I start my 92 ranger 2.3, it idles really rough....then dies. I can start it right back up and it will run fine all day long. Anyone ever had the same problem? If so, how do i fix it? I have just replaced the plugs, wires, egr valve, egr sensor, air filter, fuel filter, had the injectors cleaned, and a host of other stuff, but the cold start problem remains. It runs like a top after the restart....thank goodness for that.
Old 09-24-2004, 08:53 AM
RangerX's Avatar
RangerX
RangerX is offline
when i first got my 97 it acted like that, i had to remove an clean the throtlebody. it tool most of the can of cleaner to clean it.. turned out that the idle air valve was cloged with gunk...
Old 09-24-2004, 08:57 AM
Jimmy0306's Avatar
Jimmy0306
Thanks
Ill try the idle air valve. I have no idea where it is or how to clean it, but I'm sure U can find someone to help:-)
Old 09-24-2004, 12:50 PM
RangerX's Avatar
RangerX
RangerX is offline
Originally Posted by Jimmy0306
Thanks
it's attached to the throtlebody. i had to remove it to get it totaly clean. BE CAREFUL DOING THIS. you can damage it
Old 12-27-2004, 11:33 AM
Ol Rudy's Avatar
Ol Rudy
Ol Rudy is offline
Just removed one from neighbors 96 Ranger for cleaning....watch those two little bolts...likely "stuck" so use WD40 or similiar...anti sieze on reassembly. Valves are $50 new if a good cleaning doesn't do the trick (I used carb cleaner, cue tips, etc.)
op1324
02-17-2015 09:45 AM
op1324
02-13-2015 12:20 AM
Nighteyez
4 Cylinder Engines
02-08-2008 11:02 AM
4dtough
11-20-2007 06:28 AM
Critterhunter
1983 - 2012 Ranger & B-Series
10-19-2002 11:03 PM
Quick Reply: 2.3 Cold Startup Problem
