Spark Plugs
Spark Plugs
What you've got John is a dual plug head with plugs on the intake side as well as the exhaust side. This provides more complete combustion for greater eficiency.Also,those are not dist. caps,they are coil packs,part of the distributorless ignition system {DIS}.The other parts include a crank position sensor,module assy.,knock sensor and are all controlled by engine computer. The beauty about all this is there are no moving parts to wear out,but a simple failure will result in no ignition spark or fuel pump signal to run engine.
Phillip
Phillip
Phillip
Phillip
And have they reached what they wanted to do with this system?
Originally Posted by JohnAW
Has there be much trouble with this system?
More on Ford electronic ignitions here: Ford DIS & EDIS Ignition Systems
The only trouble that I have experienced with this system is changing the last two plugs on the intake manifold side. You either need a multitude of ratchet extensions and u-joints, or you need to take off the upper intake manifold to reach them. But with the Motorcraft double platinum plugs...you only need to do this once every 100k miles...if that.
I would say that that the system is a success overall. The great thing is that one bank of plugs isn't firing all the time, only when needed, so this saves on the wear of that one bank (can't remember which side).
just changed all 8 plugs and wires on our 89 2.5 today. 6 plugs were fun the 2 under the intake were really fun. a very l o n g extention was all we needed and it did't take long to do this. BUT the plug wires yes the plug wires under the intake, that took a lot of time to get done. we did it but we work hard on it. also the 2 plugs under the intake dated back to 1989 some one only put in 6 plugs in on the last tune up just like the wires were from 1989 also. we used a very long needle nose to get the plug wires off. took about 4 to 5 hours and we were all done with the job. and it runs real well.
ron
ron
