Spin-On Oil Filter Adapter (292) - Ford Truck Enthusiasts Forums
Old 12-27-2004, 02:55 PM
AtypclEngr AtypclEngr is offline
AtypclEngr is starting off with a positive reputation.
My spin-on oil filter adapter has started to leak around the edge. I'm not the one that originally installed it, so I'm not sure how it installs in order to remove it and reseal it. Does the center nut spin independently, or does the entire nut and plate spin? It seemed awful tight and I thought I'd better check before I tear something up.
Eric
Old 12-27-2004, 04:56 PM
312 312 is offline
312 is starting off with a positive reputation.
the nut spins by itself.there as tight as hell.be careful not to strip the nut.there things are hard to stop leaking.tou will see the gasget when it comes of.wipe of all oil and put it on dry.sometimes its sprung and even when the nut is tight it doesnt hold.whatever you do dont use any silicone around it.
Old 01-28-2013, 06:11 PM
135RECORDS 135RECORDS is offline
135RECORDS is starting off with a positive reputation.
"put it on dry.sometimes its sprung and even when the nut is tight it doesnt hold.whatever you do dont use any silicone around it."
Thanks for the info, I've been having a terrible time getting it installed correctly. I actually tried silicone and it still leaked so I cleaned it again yesterday and am going to install it dry now. Hopefully I get it to hold.
Old 01-28-2013, 11:32 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
The nut is very tight and because it is thin, it can be difficult to remove. If you look at the socket you use to remove it, you will notice a bevel on the inside. If you grind the socket on a belt sander, or carefully with a grinding wheel until that bevel is gone, it will "grip" the nut much better.
With regards to the leak, have a look at the following link:
Oil Filter
Old 01-28-2013, 11:47 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
HAND TIGHTEN OIL FILTER ONLY ~ Do not use an oil filter wrench, as filter will soon split open. Not Pleasant!
Mounting plate separate part from threaded insert, gasket between plate and block.
B7A-6882-A .. "Spin-On" Oil Filter Adapter Kit-Includes threaded insert, mounting plate and gasket (Motorcraft FL-766) / Obsolete
Passenger Car & Truck applications: 215/223/262 I-6's & 239/256/272/292/312 Y blocks.
WARREN DISTRIBUTING INC. (Motorcraft Jobber) in Santa Monica/Santa Fe Springs/Ventura CA has 4 = 562-789-3360.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1,232 (!) = 800-476-9653.
EAA-6838-A .. Spin-On Oil Filter Adapter Mounting Gasket / Obsolete
KINSEL has 4.
GREEN SALES has 6.
CARPENTER has 19.
DICKERSON MOTOR CO. in York SC has 32 = 803-684-4225.
Old 01-29-2013, 11:59 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
I was just curious, my 223 and my 292 and several I had in the past have a spin on filter.
1. Were these a dealer installed option at some point?
2. Why weren't they installed from the factory, or when did they start installing them?
Old 01-29-2013, 12:06 PM
1952/64: Came with the "sock" by-pass cannister filter as standard equipment. Called a "sock" because the original cannister filters were wrapped with white meshed gauze material.
Many FoMoCo dealer 'lube men' replaced the by-pass sock filters with full flow 'Spin-On" filters. Changing a sock filter was a messy, time consuming operation.
1957: B7A-6882-A .. FoMoCo dealer installed "Spin-On" oil filter kit introduced.
1957: B7A-6731-A .. "Spin-On" oil filter introduced. Today, this filter is: Motorcraft FL-1A
Old 01-29-2013, 12:09 PM
hiball3985's Avatar
Quote:
Originally Posted by NumberDummy View Post
Came with the "sock" cannister filter as standard equipment. Called a "sock" because the original cannister filters were wrapped with white meshed gauze material.
1957: B7A-6882-A Dealer installed kit introduced.
Thank you. I still wonder why the factory continued to use cannister rather then the spin on
Old 01-29-2013, 12:25 PM
Quote:
Originally Posted by hiball3985 View Post
Thank you. I still wonder why the factory continued to use cannister rather then the spin on.
All 1958 and later FE engines came with the "Spin-On" filter as standard equipment. It's the same puppy.
1975: FoMoCo "shoehorned" 302 engines into Mustang II's (basically a Pinto w/different sheet metal ).
FL-1A was too long, so these cars came with the FL-300 Spin-On that is shorter.
Old 01-29-2013, 12:32 PM
hiball3985's Avatar
FL-1A was too long, so these cars came with FL-300 spin-ons that are shorter.
Yes they had spin-ons on FE's but that's a whole different type of adapter. I'm just trying to find out why they didn't use them on Y blocks?
Old 01-29-2013, 03:28 PM
Yes they had spin-ons on FE's but that's a whole different type of adapter (but the same filter). I'm just trying to find out why they didn't use them on Y blocks?
They did use them on Y blocks, but it was a dealer installed kit AFAIK
Old 01-29-2013, 04:02 PM
hiball3985's Avatar
OK, I should have worded that differently.
Why didn't they put them on at the factory rather then making them just a dealer option? Doesn't make any sense to me.
Old 01-29-2013, 04:10 PM
When you figure what FoMoCo did and didn't do, and why, let me know. The idiots took over the asylum years ago.
And, who would know today? "The Deuce" and most of his compadres are as dead as Julius Caesar. Lee Iacocca is still alive, why don't you ask him.
Old 01-29-2013, 05:00 PM
hiball3985's Avatar
Who knows and I guess I'll never find out. Maybe some relative had the contract to make canisters
Spin-on Oil Filter Adapter for 223? Bobs65F600 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 11-10-2016 03:58 PM
1961 oil filter conversion, 292, Please advise kooper909 1961 - 1966 F-100 & Larger F-Series Trucks 24 11-14-2015 07:25 AM
223 I-6 Oil Filter Cartridge Woes Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-13-2014 01:47 PM
Oil Filter Thread Size Great Danes 6.7L Power Stroke Diesel 2 11-03-2010 06:02 PM
460 Swap-oil filter dilemma justshootme84 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 11-18-2006 06:54 AM
Tags
adapter, f100, filter, spin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
