Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-24-2004, 11:55 AM
brown79 brown79 is offline
Garage is empty, add now
brown79 is starting off with a positive reputation.
propane?
my unit (79 f150 2wd 460 auto) runs on propane. i want more horse power but the propane here is 58% cheaper than 87 octane gas. any ideas?
  #2 (permalink)
Old 12-24-2004, 01:20 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Change it back and start running gas. If you want more power you have to give up something.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
  #3 (permalink)
Old 12-24-2004, 01:22 PM
84-250 84-250 is offline
84-250 is gaining momentum as a positive member of FTE.
rebuild the engine with higher compression- 11:1 or around there
rebuild the engine for twin turbos (forged internals)
__________________
1994.5 F350 CC PSD 5sp 4x4
T409 Downpipe & Cat Delete,6637, Valair 01HD Clutch
140V IDM, Pyro, Terminator Scangauge, Beans Tunes, Beans Stage 1s, Traction Bars
1984 F250 (RIP) PM me for parts
  #4 (permalink)
Old 12-25-2004, 10:40 AM
canda250 canda250 is offline
canda250 is starting off with a positive reputation.
I have 2- 1979 Ford trucks on propane. If your truck has been on propane all its life like mine, the heads and carb will be damaged and have to be replaced along with any other rubber fuel line parts. I need a rebuild on the bearings on my 302 and intend to put mine on unleaded during this process. I live in OK and propane is not cheap.
  #5 (permalink)
Old 12-25-2004, 12:23 PM
ivanribic ivanribic is offline
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
Quote:
This is what I would do if propane was that much cheaper than gas. I believe propane is around 110 octane so you can run extremely high compression on it. Some of the guys with propane powered competitoin buggies are running 13:1.
  #6 (permalink)
Old 12-25-2004, 11:18 PM
Phinxter's Avatar
Phinxter Phinxter is offline
1992 Ford Ranger
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
Quote:
Actually propane is 118 octane. You could go higher than 13:1, Cummins makes 2 versions of it's B series diesel converted to run on either LPG or CNG and if I'm not mistaken they are around 18:1. You also need to advance the timing running propane and you could even have the Distrib advance recurved.
__________________
Phinxter "Have you ever worked on a Caddy?"
1992 Ford Ranger Danger 3.0 5spd 4X2
1993 Plymouth Sundance (Member of the Allpar 200k club)
2009 Saturn Aura
2004 Jeep Grand Cherokee Limited V8
  #7 (permalink)
Old 01-01-2005, 01:37 AM
hot1958 hot1958 is offline
hot1958 is starting off with a positive reputation.
hey guy's,does any body know any good book's or source's for info on installing and tuning propane.any help would be great,thanx/scott.
__________________
build it strong,and drive it like you stold it.
  #8 (permalink)
Old 01-01-2005, 02:22 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
http://www.mergetel.com/~fraso/RasoE...ks-Propane.htm
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #9 (permalink)
Old 01-01-2005, 10:14 AM
hey dave,thanx/scott.
__________________
Tags
1993, 84, f150, f250, ford, octane, propane, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
