360, 390, or 428? - Ford Truck Enthusiasts Forums
360, 390, or 428?
Old 12-23-2004, 11:56 PM
Gregorri Gregorri is offline
Gregorri is starting off with a positive reputation.
360, 390, or 428?
I have three motors. I plan to put one of them in my truck. I have a 360, 390 high proformance and a 428 maruader. Which does everyone think I should go with? I want something that can put on the odd smoke show here and there. Does anyone know the valve sizes for a stock 428 marauder? I would like to have the truck run on regular gas. Should I just take the heads and intake off the 390 and beef up the 360? I'm not expecting much milage wise but regular gas would save money.
Thanks
Rick
Old 12-24-2004, 12:13 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
If they are are all in good shape, probably the 390. Put the timing at 6 degrees and go light on the throttle and you can squeek by on regular most of the time.
I say that because despite what I've learned here about 360s, (that they are just short stroke 390s) I still hate them because everyone I knew when they came out hated them.
And the 428 would be worth enough to run your truck for a year or two.....
Old 12-24-2004, 12:43 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Moved to proper forum.
Old 12-24-2004, 07:13 AM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
What casting number is on the 428 heads?
Old 12-24-2004, 01:33 PM
Six Niner Six Niner is offline
Six Niner is starting off with a positive reputation.
dont know any of the details of each motor but the 428 would probably get my vote.
Old 12-24-2004, 02:23 PM
yomow yomow is offline
yomow is starting off with a positive reputation.
I wish I had this problem !!! 428 is my vote .
Don
Old 12-24-2004, 05:14 PM
360, 390 or 428?
The 360 has 130 00 miles, 390 has a lilttle over 100 000 and the 428 only has 60 000 miles. The 390 hi po has about 400 hp but the 428 has 350 and thats stock. The 428 is only missing the valves, other then that it looks good. The 428 was torn down right after it was pulled 20 years ago. The heads have minor rust on them, everything else looks good. Is it worth the money to clean up the heads and buy new valves? How would I tell what size of valves I need? I'll try to get the casting numbers later tonight.
Thanks
Rick
Old 12-24-2004, 05:50 PM
jstandle's Avatar
jstandle jstandle is offline
jstandle is starting off with a positive reputation.
428 hands down. bigger is better.
Old 12-24-2004, 10:34 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
i would put in the 428
Old 12-26-2004, 08:35 AM
FFR428's Avatar
Needsmorecoffee.
Thanks the casting numbers from the heads will help tell if they are std or CJ heads. Does the back of the 428 block have a sandscratch " A or C " ? G.
Old 12-26-2004, 06:25 PM
Numbers
The casting number on the head is C8AE-H. There is another number in the retainers for the springs, 9Fll. Hope this helps to figure out the valve sizes and I will try to get the block numbers tomorrow.
Thanks
Rick
Old 12-27-2004, 08:35 AM
FFR428's Avatar
Needsmorecoffee.
Yep the C8AE-H heads are the standard 360/390/428 heads with 2.02 intake and 1.55 exaust valves. The CJ heads had a little bigger valve and a few more cc's in the head chamber. 9F11 is the date code of 69/June/11th. When you look at the block check the crank saddle area and look for double or triple webbing. The "A" 428 blocks normally have the double and the "C" CJ 428 block the triple. Also inside the center freeze plug look for the 428 cast inside and double check the 4.13 cyl bore. If it's a production 428 it will have either the A or C on the back. If it has no casting numbers at all and some vertical ribs on the outside of the block it could be a service block. G.
Old 12-29-2004, 11:16 AM
360, 390 or 428
I know the whole motor is stock so I'm almost positive that it won't be a CJ. If the heads are standard 360, 390, and 428 can I take the heads off my 360 and put them on the 428 block.
Old 12-29-2004, 05:52 PM
FFR428's Avatar
Needsmorecoffee.
Sure the 360 heads will work. Just keep in mind cam lift and spring pressures when your building. G.
Old 12-29-2004, 06:34 PM
Hey, thats probably what I will do just because of the money factor. I dont know much about motors, what do you mean when you say cam lift and spring pressure? Its not a bolt on kind of a swap? If that was the case can I take the valves out of the 360 and put them in the 428 heads?I'm new to all this stuff but thats the reason why I bought my truck. Anything goes wrong I should be able to fix it.
Thanks
Rick
351M vs 428 Ford150/428/dud Engine Swaps 6 04-09-2005 07:54 PM
360-428??? 77fordguy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-15-2005 09:36 AM
360 to 428 swap Gregorri Engine Swaps 6 12-21-2004 09:39 PM
Can you turn a 390 block into a 428? highboy 74 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 12-02-2003 07:31 AM
360 to 428? Roach1161 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 05-12-2003 07:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
