Propane Injection???? - Ford Truck Enthusiasts Forums
Old 12-23-2004, 09:59 PM
F-250 diesel F-250 diesel is offline
F-250 diesel is starting off with a positive reputation.
Has anyone installed the Bullydog or any type of propane injection to their 7.3?? just wondering b/c i heard it gives alot more power while using very little propane. and how much does it cost, i remember seeing on the tv show TRUCKS they put the Bullydog system in the duramax and got dramatic power gains, and its only around 700 bucks i heard. the only thing is that the tank and all that weighs alot and where would you mount it if you dont want to put it in the bed???could you put it underneath??
Old 12-23-2004, 10:19 PM
kilapapipa kilapapipa is offline
kilapapipa is starting off with a positive reputation.
I have a buddy that tells me that you better have good injectors to use propane or you will fry them.
I have heard that it burns the diesel to 90%+ with cooler EGT's as well.
Old 12-23-2004, 10:20 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Several folks here use Propane injection and I am in the process of installing it. Probably the most knowledgable person here on the subject is Quadzilla.
He runs a Powershot 2000, same system I am putting in. Its a vapor phase system and has some advantages, including saftey, over the Bullydog which is a liquid phase system. Either works well if set up properly but if not properly set up they each can ruin your engine.
Old 12-24-2004, 06:53 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
I put a Powershot2000 system on my truck two years ago, and have found it to be a great way to add power. Installing the system is really quite easy. Deciding what tank(s) you're going to use, and where you'll put them will take a little thought, though. I decided to get a 9.9 gallon Manchester tank, and mount it under the truck, so I could keep the bed clear. Now for your specific questions:
I've seen a 80hp increase on a dyno with the propane. That's significant. A lot of chips/tuners advertise a 60/80/100/125hp increase, but they sure don't dyno like that. A 100hp chip will show a 20hp increase on the dyno. This is a true 80hp increase on the ground. Yeah, way more than a chip.
In every day use, I go more than 2000 miles before needing to refill the propane tank.
You can keep the cost down considerably if you're willing to use BBQ bottles in the bed of the truck, but I wanted a more permanent installation, so going with the Manchester under the bed ran my initial expense up, but I have no regrets at all. My total cost for the system, tank, other modifications to improve the system: less than $1000. My tank alone was around $300.
Click here for a close up of my tank under the truck.
Click here for a long range shot of the driver's side. The tank isn't too obtrusive, I guess.
Old 12-24-2004, 10:14 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
I sure like your truck Quadzilla. Very nicely done.
Old 12-24-2004, 11:06 AM
Quadzilla, where did you get your kit from and did you have to put different injectors in it or no? and did you install it?
Old 12-24-2004, 12:45 PM
cowboy49 cowboy49 is offline
cowboy49 is starting off with a positive reputation.
heres something to consider, go to a junkyard find a wrecked motorhome that snag the propane bottle off of it fo way cheap, get it inspected fo 20 bucks that mount it under youre cab
Old 12-24-2004, 05:01 PM
Quadzilla's Avatar
Thanks, Special "K"!
I bought the system and tank from Dale Isley at TYMAR. There's a lot more to TYMAR than just intakes. That's why a TYMAR sticker is the only one on my truck.
Stock injectors, for now. Baby Swamps are in my future, though.
Quote:
did you install it?
With the help of a friend, yes. I swung through Spokane prior to getting the system, and Dale took some measurements of my truck, so he could fabricate the mounting brackets. After having them powdercoated, he shipped them to me. The whole installation took about 4-5 hours.
Old 12-24-2004, 05:08 PM
hmmm, pretty sweet, i guess im gonna have to look into that lol, and whats the website for powershot?
Phydeaux88's Avatar
Quote:
I also purchased my Powershot 2000 from Dale and saved $50 over ordering it from the manufacturer.
Powershot web site is http://www.dieselperformanceproducts.com/home.html
Old 12-24-2004, 05:10 PM
who is this Dale guy that your talking about? and does he have a website???
Old 12-24-2004, 07:43 PM
Quadzilla's Avatar
Dale Isley is the man behind TYMAR. He's best known for his intakes, but also sells propane systems, chips, exhaust systems, etc. His phone number is 509-922-8785.
Old 12-24-2004, 08:02 PM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
dale isley
tymarperformance.com
webpage isnt much right now
509 922 8785
im gonna jump on the propane bandwagon here soon. havent decided between propane or intercooler first. seen a couple used setups on the dieselstop for sale
hey quad did you intercool that truck yet?
Old 12-24-2004, 08:58 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
So Quad. this seems to be getting into an interesting thread. I have all this extra money BURNING a hole in my pocket, and I pretty much have a chip picked out, but do you think that the propane would be a better idea, I am not towing anything. strictly a rice racer, weekend go fast machine.
after reading this thread, and a few others on the propane injection I am now leaning towards the 'pane before I get a chip, strictly because the gains of propane are far better then that of a chip, is this correct?? what did you do first and what would you do if you had to build your truck all over again, chip or pane first???
Diesel Rod
Old 12-24-2004, 09:19 PM
Quadzilla's Avatar
No, but it's on my list of things to try to get done this year. Also on the list are a BTS tranny, and Baby Swamp injectors.
My truck might have been a little different than yours when it was stock, so let's walk through my decision making at that time. My truck is a '95, which means it had the TEE5 box code. That happens to be a very powerful code, but also is the least user-friendly. The shift parameters, and glow plug logic are downright hideous. I wanted a chip first, because I could change the personality of the truck, as well as add more power. By installing a TDE0 code chip, I got more power than the TEE5 had stock, plus I got a very driveable truck. The glow plug logic is far superior, and the torque convertor lockup characteristics are also the best available on a OBS truck. After doing the routine mods: intake, exhaust, gauges, tranny mods, and chip, I was ready for more power to go with the new personality of the truck. Adding propane last made sense in my situation. It might not in yours. I'd get the other foundation laid first, and if you're happy with the box code of your truck, you don't have to have a chip to get the benefits of propane. A chip that's programmed with propane as part of the equation will enhance the benefit, but isn't a prerequisite.
Another thing to consider..... A chip that is programmed for use without propane will need to be reprogrammed for use with propane. If you want to get the chip first, verify that the person programming the chip can later reprogram it for propane use. Most all chip programmers can do this, but it's still wise to check first.
Bullydog Propane Tank jonnybronco Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 03-07-2014 12:27 AM
6.0L In '08 E-350s In Short Supply? vincewood30 1968-2013 Full Size Vans 0 11-20-2007 10:29 AM
Propane injection kit installed bcford6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-19-2006 11:53 AM
Propane Injection? BigDog83 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 12-12-2005 11:58 PM
Propane versus Nitrous Oxide edub32 Bio-diesel, Propane & Alternative Diesel Engine Fuels 15 04-09-2005 06:33 AM
Tags
359, 5099228785, 73, cheap, diesel, ford, idi, injection, inline, motor, peterbilt, programing, propane, put, tee5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
