2001 Explorer Sport 4.0 SOHC Rough Idle
Old 12-23-2004, 11:29 AM
photog3740's Avatar
photog3740
photog3740 is offline
Question 2001 Explorer Sport 4.0 SOHC Rough Idle
I have a 2001 Explorer Sport 4.0 SOHC with 62000 mi. on it. When I press on the accelerator with the vehicle in park, it will start to idle very rough above 3200 rpm (cannot get above 3200). This happens if the engine is cold or warmed up. It doesn't seem to cut out and drives OK. I have replaced the spark plugs, but this didn't correct the problem. Not sure if this is a sensor, plugged injectors, etc.. Any help would be appreciated.
Old 12-23-2004, 11:21 PM
NRidgely's Avatar
NRidgely
NRidgely is offline
mine does the same thing, it only goes above 3000 when its engaged in gear, i've always assumed it had a control to stop it from reving that high while not moving, then again i dont see a reaosn to rev it that high unless u were just looking to listen to it
Old 01-06-2005, 01:18 PM
cjk2001's Avatar
cjk2001
cjk2001 is offline
Thumbs up limiter
Your truck should have a rev limiter on it to prevent blowing the thing up when not driving and in park. I know this reply is late, but I just joined and seen this post, so I thought I would reply. It sounds to me that your truck is running just the way it is designed to do. I think the plugs or what ever you replaced was a bit of a loss, but on the same hand, new parts never hurt, right?
Matthew Redmond
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-05-2017 10:36 PM
Ryleystr
02-12-2016 01:24 PM
De1fan
11-29-2015 09:40 PM
bhays77
07-23-2014 09:23 PM
Sniper_Clown
02-23-2011 08:59 PM
Quick Reply: 2001 Explorer Sport 4.0 SOHC Rough Idle
