1994 ford ranger mass air flow problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-21-1999, 01:36 PM
pae pae is offline
pae is starting off with a positive reputation.
Ihave a 1994 ford ranger with 2.3l 4 cylinder engine. i have replced the egr valve, egr relay and now is giving me a mass air flow error when i read the computer. the engine makes a reving noise and doesn't have good power. my gas milage has gone from 20 mpg to 15 mpg. also if the vehicle stalls when backing up i can't start the vehicle and the computer gives me an open fuel pump relay. if i let the truck sit for about 10 minutes it will start. if anyone can help me i'd appreciate it.
thanks pat
Old 07-26-1999, 06:23 PM
john john is offline
john is starting off with a positive reputation.
did you try taking off your gas cap
if this works
look at your fuel return lines & canister
may be stoped up
let me know
john
Old 08-03-1999, 04:15 PM
Tim Raymer
Guest
Posts: n/a
Similiar set of circumstances on my 95 contour turned out to be blocked Catalytic Converter.
Tim Raymer
>appreciate it. thanks pat
Old 05-04-2000, 10:56 AM
pajamas pajamas is offline
pajamas is starting off with a positive reputation.
>the computer.
Please help. I desperately need to know how to read the computer on my 93 ranger. There is an ECC TEST module with 6 connections near my power distribution box on the left. I've been getting a check engine light occasionally and have been wanting to know how to read the codes. http://dalidesign.com/hbook/eectest.html has some info but I'd like to know how you do it. Please post here and email me at jiml@hal-pc.org with your procedure.
thanks
Jim
Old 05-11-2000, 11:54 AM
Brian.Norman Brian.Norman is offline
Brian.Norman is starting off with a positive reputation.
I have 94 Ranger 4.0 with similar symtoms: will stall sometimes after releasing accelerator or sometimes after shutting off the engine if I try to restart immediately it only cranks. If I leave it sit for 10 min. it starts OK. Sometimes when idling for no reason the RPM increases a little as if it was about to stall and the computer gives it more gas.
How did you finally fix the 93 Ranger?
Thanks.
Old 05-12-2000, 01:47 AM
mmoore mmoore is offline
mmoore is starting off with a positive reputation.
Calculate MPG for Ford Diesel runnerAZ 6.0L Power Stroke Diesel 7 11-25-2014 04:54 PM
codes are telling me egr valve and mass air flow hotrod9969 Explorer, Sport Trac, Mountaineer & Aviator 5 02-12-2010 12:47 AM
Where's the mass air flow sensor on a 86 2.9? unioncreek 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 2 01-19-2007 11:52 PM
85 Ranger 2.8 no vacuum to egr valve cctrader2000 Ranger & B-Series 2 08-26-2004 08:47 AM
Fuel Pump Problems... stacyj 1987 - 1996 F150 & Larger F-Series Trucks 2 02-25-2004 10:42 AM
Tags
1994, 94, 99, air, egr, ford, pump, ranger, restart, specs, stall, stalling, stalls, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
