Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-21-2004, 01:15 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Adapting 48-49 front hubs to 46 spindles
I have 48-49 F-1 hubs on 46 spindles. They required machined bushings due to the larger inner bearings. About 10-12 years ago an article appeared giving a bearing number for the application, that did not require the bushings. Does anyone happen to know that bearing?
Just trying to clean up loose ends on this project. Mike
__________________
1946 1/2 ton with Y-block
1962 Unibody F-100
1990 Ranger 4WD
1954 Model 600 tractor
  #2 (permalink)
Old 12-21-2004, 10:25 AM
mtflat mtflat is offline
mtflat is gaining momentum as a positive member of FTE. mtflat is gaining momentum as a positive member of FTE.
I remember seeing the info a long time ago on one of the forums, but........ What I do recall was they got the bearing by taking a micrometer reading of the OD of the spindle (ID of the bearing needed) and the OD of the bearing and finding a good bearing shop. They should be able to cross reference the #'s for you.
  #3 (permalink)
Old 12-21-2004, 06:32 PM
45ford's Avatar
45ford 45ford is offline
45ford is starting off with a positive reputation.
Mike:
This is what I have on my computer. It's for '53-'56 F-100's, but I'm 99.99% sure that F-1's use the same parts.
Inner Seal-
Napa 15214
C.R. 15214
Chicago Rawhide 35461
JKL 49461
National 450461
Victor 49195
Inner Cup-
Timken 14276
Inner Bearing-
Timken 14116
Outer Bearing-
Timken 09067
Outer Cup-
Timken 09195
Wheel Stud-
Balkamp 641-1142
If I remember correctly, the inner bearing has a slightly tighter curve to it and must be "hogged out" a little with a die grinder.
Mike
  #4 (permalink)
Old 12-21-2004, 08:29 PM
46yblock's Avatar
45ford, that is some great information, even if the 53-56 hubs are different than F-1. Do I understand correctly that those are part numbers to put 53-56 F-100 hubs on 46 spindles? If so I will just go to one of the other forums and ask if the F-1 hubs and early F-100 hubs are the same. Mike
__________________
1962 Unibody F-100
1990 Ranger 4WD
  #5 (permalink)
Old 12-21-2004, 10:48 PM
45ford's Avatar
Mike:
Hmmm, looking at the 48-56 Ford truck chassis catalog, those numbers I gave you may be the stock ones for the F-1 and F-100.
Let me look around, I have the correct numbers to double check with.
Mike
  #6 (permalink)
Old 12-22-2004, 05:29 PM
45ford's Avatar
Okay, Mike, here we go again. These numbers were published last summer in Rod & Custom, so they should be good:
Inner Bearing: Timken 14116
Inner Race: Timken 14276
Seal: 473440
Out bearing & race are as stock (F-1, F-100, and earlier Ford use the same parts)
F-1's and F-100's use the same bearing set (double checking this is where I discovered that the first set of number I gave you were stock replacements). They have different spindles, hubs, & brake drums. Some internet searching this morning found several statements saying that F-1 brakes bolt to earlier Ford spindles using the same parts as the F-100 brakes (which is what I was 99.99% sure about).
An alternative to the above that I've used twice for installation on a dropped axle is to use the F-1 spindles (which most people consider to be "worthless") and therefore really cheap, instead of the 42-48 passenger/42-47 truck spindles which can sell for upwards of $100. I then cut the steering arms off and round the base, and use standard early Ford street rod type bolt on steering arms, which I have found at swapmeets for $10-15.
The F-1 spindles use the same kingpin set as the 42-47 Ford trucks.
BTW, the F-1 axle was listed as the factory replacement for the 42-47 and has a boss built into it to mount a tube shock mount.
Mike
  #7 (permalink)
Old 12-22-2004, 09:14 PM
46yblock's Avatar
Hubs, brakes, etc.
Mike, I am using the 48-49 front brakes along with the F-1 hubs, mounted to 46 spindles. I cut the steering arms off the spindles and attached aftermarket dropped steering arms. Relatively recently I obtained some F-1 spindles after junking out a 49, but thought the kingpins were larger in the F-1's compared to the previous generation. In fact I was thinking about putting them, the drag link, and another component for sale here in the classifieds. Maybe I'll take a closer look at them for my own use. Is there any particular reason they are considered worthless, like due to some design problem?
My reason for using the F-1 components was because of the larger inner bearing, and a more up to date drum brake design.
Thanks for your research and info. It has filled a couple holes for me. Mike
__________________
1962 Unibody F-100
1990 Ranger 4WD
  #8 (permalink)
Old 12-23-2004, 10:27 AM
There's no problem with the F1 setup - I'm running stock on the 48 with no troubles at all. I think it's just that so many guys pull them off and install MII that there's a surplus at the present time.
Only inconvenience I can see is the cost of new front drums due to the extra 1/2" offset. Unique to 48-52 as you probably know.
  #9 (permalink)
Old 12-23-2004, 11:59 AM
46yblock's Avatar
Mike and MT Flat, thanks once again. The numbers are written down and filed. Mike
__________________
1962 Unibody F-100
1990 Ranger 4WD
  #10 (permalink)
Old 12-30-2004, 12:30 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
"Only inconvenience I can see is the cost of new front drums due to the extra 1/2" offset. Unique to 48-52 as you probably know."
Acctually, when I redid the front brakes on my F-1 I used the rear drums from a '70s Ford F-150. They are 2-1/2" drums that fit perfectly in the place of the origionals. Don't know the part number though.
Clayton
__________________
forum guidelines
  #11 (permalink)
Old 12-30-2004, 08:12 PM
46yblock's Avatar
That is another great piece of info. Somebody on the 48-60 Forum might know the number.
The drums on now are probably ruined. I took them into a machine shop to have them balanced, and when I got them back there were so many holes drilled in them that they looked like swiss cheese.
__________________
1962 Unibody F-100
1990 Ranger 4WD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
