Heater core replacement? - Ford Truck Enthusiasts Forums
Old 12-20-2004, 11:41 PM
Dustin_86 Dustin_86 is offline
Dustin_86 is starting off with a positive reputation.
Question Heater core replacement?
How hard is the heater core to replace in my 86 ext cab f150 auto efi 302? How much will the heater core cost?
Thanks
Dustin
Old 12-21-2004, 07:50 AM
Holmesuser01 Holmesuser01 is offline
Holmesuser01 is starting off with a positive reputation.
Red face
I've replaced cores on both my '83, and '84. The '83 has A/C.
Both cores cost me around $25 at the local stores.
There are other topic threads here that go into detail what has to be done. The A/C version is easier to do, IMHO...
After you change the core, everytime you turn the heater on, you will feel kinda warm inside, because you know that YOU did it yourself, and didn't have to pay someone else.
I really like that feeling.
Old 12-21-2004, 04:02 PM
helluvaday helluvaday is offline
helluvaday is starting off with a positive reputation.
i love that feeling, but yeh hes right there cheap and pretty easy to do even if the garage make u pay a lot-it just takes some patience. Even if the whole dash has to be pulled its nothing to worry about because if you cant finish it before you go to work the next day just drive without a dash. Good luck!
Eric
Old 12-25-2004, 01:06 PM
SCAS SCAS is offline
SCAS is starting off with a positive reputation.
I'm not mechanically inclined, but I did mine in about three hours, it took me long, cause I had to buy screw drivers cause I lost mine, but I was easy, and fun at the same time..
Old 12-25-2004, 11:22 PM
1984 f250 1984 f250 is offline
1984 f250 is starting off with a positive reputation.
but it can be stressfull trying to find all the screws hold the dash in.
Old 12-29-2004, 10:23 PM
BoomerPower BoomerPower is offline
BoomerPower is starting off with a positive reputation.
Question
I have to replace my heater core in my 1980 F350. I've never done one before but is there anyway to get around not having to take the dash all apart?
Old 12-29-2004, 10:45 PM
victorcharlie victorcharlie is offline
victorcharlie is starting off with a positive reputation.
Very easy to do....cost $14 at autozone......
Old 12-30-2004, 07:25 PM
macman85602's Avatar
macman85602 macman85602 is offline
macman85602 is starting off with a positive reputation.
The easyist way to replace the heater core is to pull the glovebox out and you can get right to the heater box. remove the cover disconnect the heater hoses under the hood and pull the heater core out. and installation is the reverse of removal.
did mine in about 45 min
scott
Old 01-07-2005, 11:29 AM
dloud2002 dloud2002 is offline
dloud2002 is starting off with a positive reputation.
Thumbs up What truck macman?
I have an '83 F250 old utility truck with the big ole' toolbox bed and ladder rack. But I have no heat! I need to replace the heater core in mine and was wondering what type and style truck you were referring to macman. Or are they pretty much universal to change. I've never done one before but living here in the frozen wasteland of Wisconsin USA, I gotta have heat!! Thanks in advance...Dave..
Old 01-07-2005, 12:28 PM
86nWerkn 86nWerkn is offline
86nWerkn is starting off with a positive reputation.
I just replaced the heater core in my 86 F-150 302 EFI and it took me about 30 minutes from start to finish and the core was ony 18 dollars at Advance. Just remove the glove box and you will see the cover right behind it in which you will find the core. Remove the cover. The heater hoses in the engine compartment will not lose much fluid if you keep the hoses higher than the rest of the engine.
Old 01-07-2005, 12:30 PM
big hoss 29's Avatar
big hoss 29 big hoss 29 is offline
big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.
If your truck has A/C, the heater core should come out from under the dash. If you take the glove box out, take all the screws out around the heater core, it should only take about 20 min to take out.
If you don't have A/C, it will come out from the engine bay. You have a couple of screws inside the cab, but the rest will be in the engine bay. When you unscrew them, and take the heater core out, make sure you clean the inside of the box out. It should only take you 45 min. from start to finish.
One more thing, heater hose is cheap, so replace it and then you know it's all good. I changed the thermostat as well when I changed my heater core 2 months ago, but you don't have to do this.
Good luck!
Dan
Old 01-07-2005, 03:56 PM
All trucks from about 80 until 94 used the same basic design for the heater core and they come out the same way.
Scott
Old 01-07-2005, 05:30 PM
Well, I've got an 86 F-250 with no A/C and the heater core came out in the engine bay. If you look through a Chilton's repair manual, it'll say the same thing, the heater core comes out under the dash in an A/C vehicle and from the engine bay in a non-A/C truck. I thought they all came out from under the dash as well until I replaced mine 2 months ago.
Old 01-08-2005, 12:28 AM
I changed my heater core on my 1980 F350. There's no need to take your entire dash apart. You just need to get your glovebox out and then go from there. There isn't a whole lot of room to get the heater core cover off under the dash, the hardest part is getting it back on. I did mine in 45-hour. As long as you have a good selection of tools you'll be good to go.
Old 01-08-2005, 01:50 AM
RNE RNE is offline
RNE is starting off with a positive reputation.
The sad part about it was I kept putting it off because I assumed it was a real pain, like the Ford cars of the same period (80 -86)
Took me 30 minutes, longer to refill and bleed the cooling system than the actual replacement.
(I froze my yanos off last winter..........what an idiot!)
how to replace a heater core in a 1998 F 150 brandon olson 1997 - 2003 F150 13 12-30-2013 09:02 AM
heater core 79fordf250pickup 1987 - 1996 F150 & Larger F-Series Trucks 2 12-12-2012 02:03 PM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 03:05 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 08:55 AM
Old Blue Dustin Jacobson 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-17-2008 12:50 PM
Tags
150, 1978, 1980, 1986, 83, 84, 86, change, core, f100, f250, ford, heater, location, replace, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
