Supercharge a 1997 F350 PU w/351?
Old 12-19-2004, 08:25 PM
jmacdoug2004's Avatar
jmacdoug2004
jmacdoug2004 is offline
Thumbs up Supercharge a 1997 F350 PU w/351?
I have a 1997 F-350 XLT w/351. I am not sure which model it is (W/C/M)
I here that a supercharger will not only give you the much needed boost, but also burn fuel a bit more efficiently.
Also, will my engine withstand the boost? I/m not sure how to identify the model of my engine or where to start.
I would appreciate your suggestions.
Jeff
Old 12-19-2004, 08:40 PM
'961506's Avatar
'961506
'961506 is offline
It must be a W, cuiz c/m isnt made then.
Old 12-19-2004, 09:13 PM
jmacdoug2004
Thanks. I thought so but wasn't very sure. Any suggestions about a supercharger? Also, do you know the average "out of the box" horsepower my truck puts out? Should I just find a darn dyno somewhere to test it? I want to know the stats, especially if I MOD the engine.
Old 12-21-2004, 06:37 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
A supercharged motor will actually burn more gas when under boost. Anytime you increase airflow, you have to increase the fuel to support the added power. Under normal driving conditions your gas milage will remain the same.
A stock rotating assmebly can last a while with a good tune. Like I've said before...if you lean out the motor and/or run too much timing then your fun will be short lived, and your motor will become an oversized yard ordiment.
Edit: I wouldn't worry about a dyno run until you've installed the blower and the essential fuel system components. Dyno tunes are costly but well worth it in getting a good tune.
mac888
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
10-15-2011 09:55 PM
SFW
11-18-2006 10:18 PM
Big350
10-01-2006 08:54 PM
bronco351
1978 - 1996 Big Bronco
13
07-26-2003 06:27 AM
ryan sedy
02-25-2001 10:29 AM
Quick Reply: Supercharge a 1997 F350 PU w/351?
