Mazda 5speed in Ranger???? - Ford Truck Enthusiasts Forums
Old 12-19-2004, 03:13 PM
Old Yblockman Old Yblockman is offline
Old Yblockman is starting off with a positive reputation.
Is it possible to use a 93 Mazda 5 speed behind a 2.3 if I change the bell houseing to one from a Lima 2.3 5 speed. The tranys sure look a lot alike.
Old 12-19-2004, 03:40 PM
FLgargoyle's Avatar
FLgargoyle FLgargoyle is offline
FLgargoyle is gaining momentum as a positive member of FTE.FLgargoyle is gaining momentum as a positive member of FTE.
As far as I know, most Rangers ARE Mazda trannies. They used Mitsubishi and Toyo Kogyo in the older ones, but I think they went to mostly Mazdas. (Ford owns Mazda). There's a lot of good tranny info on the Ranger Station website in their tech articles.
Old 12-23-2004, 03:04 AM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
Mazda 5-speeds have integral bells...they can't be swapped.
If you thought The B2300 and Ranger are different, then as noted, they are not.
Old 12-23-2004, 11:08 AM
dots dots is offline
dots is starting off with a positive reputation.
mazda has used a 4 and five speed over the years in their cars and pickups that use a clutch housing that is held on with 8 bolts. it was so the same transmission could be used between the RX series and piston engines. later when they started to use ford engines in the ranger trucks and also some of the aerostars they had a housing that fit the 2300 (pinto) style motor. weather Mitsubishi or Mazda or Toyo Kogyo or Jatco built it I have no idea, but I know theyve been useing that same design since 1974 with the cast aluminum bottom cover. and the ones with this cover have clutch housings that bolt on and interchange with some other applications incl. some mitsubishi trucks and maybe some others. wow I did not intend this to be this long! hope this helps some.
Old 12-23-2004, 05:12 PM
Thanks Guys. Im finding out that what dots said above is true. I went to Pull Apart yesterday and found a 4 speed made this way.
Old 12-24-2004, 04:26 PM
RichS RichS is offline
RichS is starting off with a positive reputation.
Didn't Mazda change over to Rangers in '93? So that 93 Mazda B would actually be a Ranger clone built here in the US. It would fit behind any US 2.3. You are thinking of the old Japanese-built Mazda B series. It would just be like the Navajo and the Explorer.
Old 12-24-2004, 05:49 PM
The Mazda I have must be an early 93 as it is a old style Japanese built B2600 PU. The reason I have been asking this question is because I want to build a 2.3 Lima with 12-1 pistions in order to run it full time on propane. The 2.3 Lima is a better candidate for the conversion than the Mazda engine. I realize that I have many ather things to adapt and fabricate but if I can make the 2.3 engine fit the trany the battle is half done.
Old 12-25-2004, 04:13 PM
74crwcb429hibPS4spd's Avatar
74crwcb429hibPS4spd 74crwcb429hibPS4spd is offline
74crwcb429hibPS4spd is starting off with a positive reputation.
Does Ford own Mazda 100% or is it just a portion that Ford owns of Mazda?
Old 12-25-2004, 05:57 PM
Ford is the majority stockholder of 25%. They even have an American sit on the board of Mazda.
Old 12-25-2004, 06:01 PM
I believe the 2.3's used in the old Mazda's were Brazilian-built 2.3 versions of the US-built Lima 2.3's so they should bolt up. You could replace it easily enough with a US 2.3.
Old 12-26-2004, 12:57 PM
some of the courier & mazda 2.3 engines have both the
2.3 and the 2.0 bolt pattern on the rear of the block too.
I believe this is the same engine (design) as was used in
the old mercury capri's '74-'78 and mustang II's '74-'78.
also on that mazda trans, you can find early to mid 80's
bell housings for the german 2.6/2.8/2.9/4.0 litre V-6 eng.
they were in some rangers and areostars with std trans.
"off Topic" I know, but info is always helpful sometimes.
What do they mean the 2.3l is a Mazda design? 06RANGER Ranger & B-Series 31 01-09-2006 07:05 AM
Ford Ranger w/Mazda M5OD-R1 5-spd. short shifter kit zigzagg Ranger & B-Series 4 10-22-2005 05:35 PM
Mazda 2.3 Torque Specs minnesotasix 4 Cylinder Engines 1 10-12-2005 12:36 AM
95 2.3l ranger into a 1988 mazda b2600 2.6l rig_pig30 Ranger & B-Series 4 08-14-2005 09:58 PM
Pilot Bearing? nightme_02 Ranger & B-Series 0 10-24-2003 12:48 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, fit, ford, mazda, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
