How to Remove a 5.4 engine? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 12-18-2004, 01:58 PM
78Explorer 78Explorer is offline
78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.
Question How to Remove a 5.4 engine?
Hi All,
The more I think about it, the more I'm leaning toward replacing the engine myself in my 98 Expy. My brother-in-law has plenty of experience doing engine R&R's but not on an Expedition...
Will the engine come out of the engine bay or does the body have to be removed?
Have any of you removed a 5.4 from a 97-02 Expy? Any advice is GREATLY appreciated!
Scott
Old 12-18-2004, 10:01 PM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
FTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputation
They took the body off when they did mine. Much easier.
Old 12-18-2004, 10:18 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
If you have access to a good 2 post hoist then lifting the body is how I would do it.
If you don't have a hoist to use then yes it can be removed the "old" way.
If you decide to do it without lifting the body I would remove the inner fender liners to get at the sides of the engine. Also if you remove the front and middle body mount bolts you can raise the front of the body up a few inches to make it easier to access the bellhousing bolts and wiring at the back of the engine.
Old 12-19-2004, 04:49 AM
Thanks guys!
Unfortunately, I don't have access to a hoist to do the body lift...guess I'll have to do it the "old" way or pay Ford garage $1100 to do the swap for me...which, the more I think about it, probably isn't a bad price to let someone else deal with it.
Old 12-20-2004, 01:19 AM
bubahyde bubahyde is offline
bubahyde is starting off with a positive reputation.
I used to do alot of those. In F150s mostly but we did do as couple expeditions.
The motor will come out the top but you will need to remove the intake. The engine sits so far back that it will not come up enough to allow it to come forward. We made plates with a eye hook in the middle (Lift Point) and bolted it down were the Intake was.
Triton 5.4 for Expedition... richlester Expedition & Navigator 0 09-15-2012 01:47 PM
which is the 5.4 "3V" engine? Mark T-TB Expedition & Navigator 4 07-27-2010 03:15 PM
differences between econoline 5.4 and expedition 5.4 secondechomatt Modular V8 (4.6L, 5.4L) 2 05-30-2010 07:26 AM
'03 Expy 5.4 - Does it have a tranny drain plug cecilt Expedition & Navigator 30 02-18-2010 10:09 AM
Can the transmission set off the "service engine soon light?" quick35th Expedition & Navigator 36 08-15-2006 01:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
