98 Ranger Alignment problems
Old 10-29-2000, 09:52 PM
bobfl's Avatar
bobfl
bobfl is offline
I have a 1998 Ford Ranger that will not stay aligned. It has ruined the tires (Firestones, so
maybe it's not a big loss). Someone had mentioned to me that the Rangers had problems with the front end and there is an add-on kit to adjust the camber. He did not seem to sure about what he was saying, so I looking for more info. Does anyone know if there is a problem with the front ends or about the additional kit to be able to adjust the camber. I was not aware that this would be necessary.
Thanks
Bob W [FL]
Old 10-29-2000, 10:06 PM
bobfl's Avatar
bobfl
bobfl is offline
>(Firestones, so
>Thanks
>Bob W [FL]
I should have mentioned that this is a 2 wheel drive truck with a 3.0L automatic
Old 10-31-2000, 06:14 AM
ven0m's Avatar
ven0m
ven0m is offline
My 97 killed it's first set of tires with fairly even wear at about 36K Whihc for the firestone power puff's that come ona 2 WD ranger I thought 36 was about all that I could ask for the way I drive. I got a decent dela on some 50K rated Bridgestone's from Sears and they have performed fine for me. I will say that if you are due for a rotation (about every 6 - 8K) you will notice the truck start to pull during moderate braking. But my tires have worn just the way I expect them too.
Old 11-01-2000, 07:19 PM
jopey's Avatar
jopey
jopey is offline
Duzzi
01-07-2016 01:25 PM
94GreenTruck
1997 - 2003 F150
12-17-2014 09:25 PM
vbxt
1997-2006 Expedition & Navigator
07-26-2011 09:16 PM
garvicmos
2004 - 2008 F150
03-07-2009 09:32 AM
waverous
08-25-2005 10:45 PM
Quick Reply: 98 Ranger Alignment problems
