98 Ranger Alignment problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-29-2000, 10:52 PM
bobfl bobfl is offline
bobfl is starting off with a positive reputation.
I have a 1998 Ford Ranger that will not stay aligned. It has ruined the tires (Firestones, so
maybe it's not a big loss). Someone had mentioned to me that the Rangers had problems with the front end and there is an add-on kit to adjust the camber. He did not seem to sure about what he was saying, so I looking for more info. Does anyone know if there is a problem with the front ends or about the additional kit to be able to adjust the camber. I was not aware that this would be necessary.
Thanks
Bob W [FL]
Old 10-29-2000, 11:06 PM
>(Firestones, so
>Thanks
>Bob W [FL]
I should have mentioned that this is a 2 wheel drive truck with a 3.0L automatic
Old 10-31-2000, 07:14 AM
ven0m ven0m is offline
ven0m is starting off with a positive reputation.
My 97 killed it's first set of tires with fairly even wear at about 36K Whihc for the firestone power puff's that come ona 2 WD ranger I thought 36 was about all that I could ask for the way I drive. I got a decent dela on some 50K rated Bridgestone's from Sears and they have performed fine for me. I will say that if you are due for a rotation (about every 6 - 8K) you will notice the truck start to pull during moderate braking. But my tires have worn just the way I expect them too.
Old 11-01-2000, 08:19 PM
jopey jopey is offline
jopey is starting off with a positive reputation.
Alignment off with new front leaf springs Duzzi 1994.5 - 1997 7.3L Power Stroke Diesel 8 01-07-2016 02:25 PM
Alignment/Camber issues 94GreenTruck 1997 - 2003 F150 8 12-17-2014 10:25 PM
Will 1 degree of negative camber... vbxt Expedition & Navigator 1 07-26-2011 10:16 PM
camber kit for front end alignment garvicmos 2004 - 2008 F150 5 03-07-2009 10:32 AM
Camber Shims waverous 1999 - 2003 7.3L Power Stroke Diesel 6 08-25-2005 11:45 PM
Tags
2000, 98, adjust, alighnment, aligned, alignment, camber, end, ford, front, issue, problems, ranger, stay, truck, ur
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
