tire pressure
Originally Posted by hovy
Most know that when a tire is run it gets warm, thus increasing tire presure..All tires should be checked and adjusted while cold. On a hot summer day your tire pressures will increase quite a bit.. Ford and others try and find a mid point but your environment will determine the right cold readings. I wonder if you filled your tires in Alaska on a -25 degree day and drove to Florida into an 85 degree day how much higher you pressures yould be?
Bottom line has to be tires have a wider range psi wise to run right than we think...?
