Sealed transmission? - Ford Truck Enthusiasts Forums
Old 12-17-2004, 10:45 PM
Gary42141 Gary42141 is offline
Gary42141 is starting off with a positive reputation.
I saw this about the transmissions in the '04 F150, and I assume it's the same for the '05 model.
"A sealed case and lifetime transmission fluid make the transmission maintenance free"
So changing the transmission fluid is now a thing of the past?
Old 12-17-2004, 11:23 PM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
My opinion is that with automatics, because of the amount of heat in them and how it affects their 'lifetime' and the usable lifetime of the oil, if you leave the same oil in it for the 'lifetime' of the trans, the trans' 'lifetime' will be much shorter....
In other words, ignore the boastful advertising claim and change the oil regularly (every 30K or less) for longest transmission life.
Old 12-18-2004, 01:08 AM
I haven't checked out the transmission yet, but if it's sealed, how are you supposed to change it?
Old 12-18-2004, 09:43 AM
kennethl6 kennethl6 is offline
kennethl6 is starting off with a positive reputation.
The F150 has a dipstick so no problem. The new Explorer, TBird, LS Lincoln and 2005 Mustang don't have a dipstick. Those have to be filled through a standpipe/drain plug in the pan. If you go to a shop that has a fluid flusher, which hooks into the cooler lines, the pan is not dropped anyway. Because none of the later model trannies have converter drain plugs, the flushing method is the way to go.
Old 12-18-2004, 02:23 PM
If you're changing the fluid, you should also change the filter, which means dropping the pan. I haven't seen an auto tranny in a pickup without a pan that can be removed to change the filter and drain the oil. Of course I don't have a new truck, so maybe there is an auto truck trans out there now with no removeable pan. Sounds like a nutty idea to me though...
Old 12-18-2004, 06:12 PM
Guess I'll have to find out what "sealed" means.
Never heard of a car or truck that you couldn't change the fluid and filter on.
2001 F250 transmission leak Jay Hyde 1999 to 2016 Super Duty 2 12-21-2016 11:58 AM
transmission seal leaking markeyd 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-28-2015 08:41 PM
vacum modulator rdweathers 1973 - 1979 F-100 & Larger F-Series Trucks 18 11-11-2013 03:14 PM
transmission seal lurchy98 Ranger & B-Series 6 12-29-2004 08:21 PM
2002 explorer transmission fluid change pballernyc Explorer, Sport Trac, Mountaineer & Aviator 3 08-24-2003 06:47 PM
Tags
f150, sealed, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
