69 Dana 60 rear end w/ posi - worth it?
I am posting in this forum and not the differential forum because it is more of an opinion based on the year of the vehicle rather than specifically about the differential. I purchased a 69 f250 for a song, and as it turns out it has a Dana 60 with 4.11 gears and posi. I bought the truck originally to section part of the bedside and for the grille to install on my 68 F100 4x4. My f100 has a 9" rear end (open). Would it be worth it to swap over to the Dana 60? Is it possible to convert the 8 lug to a 5 lug pattern. Thanks for any input.
Jay
Jay
Jay
Jay
Thats a bullet-proof axle, and worth some money in the Rock Crawling/Drag racing community. if you known it is in good working order, a conversion might be worthwhile. But, you will pick up some weight with that axle. your current springs may not like it. Converting to the 3/4 ton springs might take some work.
As for the hub conversion. Im sure it's possible. but, I have not seen anything off-the-shelf.
My 2 cent opinion. Sell those parts, lock up the 9" with the gears you want. Or, just find a 9" pumpkin swap, I understand that's pretty easy.
