Low speed vibration and howling.
I've got a grinding vibration coming from the front end at very low speeds. I notice it most when I'm pulling away from my mailbox with the wheel cranked. Very troubling as it shakes the whole truck. Also, when I brake, I hear a loud howling coming from the front. It's not brake howl, this sounds & feels like a reverberation building up into the howl.
My guess is that my bearings are probably shot. How would I go about checking the bearings?
ON EDIT: The bearings and hub assembly are one in the same on our trucks, right? So basically I'll be changing out the whole hub assembly, just to replace the bearings (might even do the balljoints.)??
Yes it is a "non servicable" asembly.Leve unit out of 4WD. Remove tire and wheel. Remove brake caliper and hang off to one side. Remove locking hub.
Now you can get a better idea of how bad the bearing are turning it by hand. Sometime they go "crunch, crunch" sometimes they just wont turn much at all.
radck
10-30-2016 04:01 PM
