Camshaft Sensor - Code P0344 - Ford Truck Enthusiasts Forums
Old 12-17-2004, 01:15 PM
Dias Dias is offline
Dias is starting off with a positive reputation.
Unhappy Camshaft Sensor - Code P0344
I was just reading Todd525's problem and I have the same thing. My tuner is showing a code P0344, Camshaft Sensor problem. Can anyone tell me how to go about changing the sensor or should I take to a professional?
Old 12-17-2004, 01:27 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
the sensor is pretty easy to change, it is just under the a/c compressor at about 10:00 o-clock on the front of the engine. it is held on by a 10mm bolt and has a harness plugged into it. it is easier to get to if you take off the acc. drive belt. if you have an international dealer close you can get one there cheaper than at a ford dealer. i would bring the old one with you to make sure you get the right one. it is covered under the 5 year 100,000 mile warranty and all you would have to pay is the $100.00 deductible (i just let the dealer do it under warranty when mine went out at 35,000 miles)
Old 12-17-2004, 01:31 PM
Thanks,
I talked to the dealer where I bought the truck, and they can change it pretty quick. Should I reset my to tuner to stock setting before I let them change it?
Old 12-17-2004, 01:33 PM
The Grinch The Grinch is offline
The Grinch is starting off with a positive reputation.
I would not worry about the setting on the computer. It would not have caused the cps to die so they can not have any problem with the changeout under warrantee.
Old 12-17-2004, 01:49 PM
Is there any chance that they may change any settings to my computer? I realize that if they change anything, then my tuner want work. I also realize that if I change back to the factory settings, that I will loose my error code for them to diagnose the problem, unless it happens again after I reset it.
Old 12-17-2004, 02:29 PM
wlihntr's Avatar
Quote:
Originally Posted by Dias
Thanks,
YES, SET THE PCM BACK TO STOCK!! they will scan the pcm and if there is a program in it they could give you grief about it. even if it has nothing to do with the CMP they could document it for the future and use it against you on other warranty claims
05 Navi Codes U0100, P0158, P0345, P0349 rowekmr 1997-2006 Expedition & Navigator 4 02-15-2017 09:26 PM
2006 Expedition codes P0344 & P0581 Domino 1997-2006 Expedition & Navigator 4 07-18-2015 08:38 PM
2005 f150 5.4 v8 rough idle, cant figure it out patrick.sellers 2004 - 2008 F150 0 10-30-2011 11:50 AM
Code P0344 CPS and P1280 ICP now what? jnye6625 1994.5 - 1997 7.3L Power Stroke Diesel 20 03-07-2007 02:51 PM
5 Codes now down to 2 derekjon 1999 - 2003 7.3L Power Stroke Diesel 1 02-27-2007 04:09 PM
Tags
04, 2001, 2004, 73, camshaft, code, f150, f250, f350, ford, p0344, po1670po344, po344, powerstroke, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
