Picture of Toyota Steering Box?? - Ford Truck Enthusiasts Forums
Old 12-17-2004, 12:52 PM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
Does antone have a picture of the Toyota 4X4 Steering box that will work on a 1960 effie?
Old 12-17-2004, 07:21 PM
Kecky's Avatar
Kecky Kecky is offline
Kecky is starting off with a positive reputation.
Walston, if your stock steering box is a through frame with pitman arm and draglink then it will be the bracket that determines if you can mount it to your setup. CPP has a lot of pictures for their kits. Look at this http://www.classicperform.com/produc.../5356PSK-T.htm and see if your box is similar to the Toyota box for the 53-56 setup. You can also make your own bracket that looks like a stretched Z shape and goes between the top and bottom portion of the inside frame rail.
Sorry but my experience is with the 53-56 years but I can't see why that setup couldn't be adjusted to work on your year. You could also search past threads as others have posed the same question on the later model years.
Hope this helps.
Kevin
Old 12-17-2004, 11:03 PM
Goobzilla Goobzilla is offline
Goobzilla is starting off with a positive reputation.
I can get you a picture of the right box tomorrow. I have one sitting on the floor of my shop that's VERY photogenic. '79-84 and some 85 Toyota 4WD pickups should have what you need.
Here's a tip, if your local 4x4 clubs have a website place a wanted ad for one on there. The early Toy pickup guys part out darn near everything on those trucks. That's what I did, and in less than 24 hours I was offered at least a half dozen of them between $25-$60, so I just picked the closest one.
Ron
http://rons55ford.blogspot.com
Old 12-19-2004, 07:23 AM
Walston's Avatar
Thanks for the info. Looking forward to the picture.
Old 12-20-2004, 11:59 PM
Here's some pics, sorry for the delay. I haven't pulled off the old Toyota pitman arm or rag joint yet, so it looks a little funny. The correct early box is MUCH shorter than the later style box. Let me know if you need more info.
Ron
Old 12-21-2004, 06:20 AM
Walston's Avatar
This helps a lots, Thanks.
Old 12-21-2004, 02:48 PM
Walston's Avatar
Got one today out of an 83 in a local salvage yard, Thanks for the help.
Old 12-21-2004, 03:15 PM
Old 12-21-2004, 08:51 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Hope you got the return hose fitting with yours Walston. It's a bas***d size, and if you run into header clearance problems like I did you may need it to make a modified fitting. I've learned a LOT about power steering hoses and fittings over the last couple weeks trying to solve the problem with over the counter parts. My SS braid hoses arrived today! Won't get to put them on until the weekend tho, if she isn't covered in snow that is... Weather guessers are saying there's a slight chance of a white Xmas.
I'd much prefer the 80* one we had a couple years ago tho. 32 years of shoveling the stuff in Buffalo gave me a fill of snow for a lifetime.
Old 12-21-2004, 08:53 PM
AXracer's Avatar
Goobzilla, I ended up having to split the pitman arm and nut with a cutoff wheel, there was no way they were coming off otherwise. If you are using the heavy V shaped bolt on mount, mount the box first, you'll need to grind off the ears on the box where they overhang the mount so the mount can go up against the frame properly, and there is no way to get to the bolts once the mount is in the frame. BTDT!
Old 12-21-2004, 09:40 PM
Walston's Avatar
I did get the return fitting, thanks for the other tips. Is the v - shaped bracket worth buying? I was thinking about making my own bracket? The engine is out of my truck so interferences won't be easy to identify now.
Old 12-21-2004, 10:55 PM
AXracer's Avatar
If you're handy, you certainly could make your own bracket. The V shaped one is VERY heavy, made from ~ 1 1/4" square bar stock. For a synopsis of my install, search for my topic "progress". Interference is going to be dependent on your engine/header choices. My SBC with full length headers clears the box no problem, but the rearmost pipe on the header is ~ 2" away from and directly in line with the return hose fitting. As you know the stock fitting comes straight out so that puts the end the hose goes on right against the header
Next I tried buying the hose and adapter set Mid Fifties sells, the return hose has a right angle fitting on it which would have been perfect had it not needed an adapter to fit the box. The adapter fitting made the whole assembly ~ 1/4" too long to fit
Then I tried to have a custom hose made, but nobody makes a 17mm x 1.5 fitting except Toyota and MF which has their adapter fitting specially machined.
Finally I cut the straight aluminum tube (yes I tried bending it first) out of the stock fitting and cut a right angle bent steel tube off the OEM pressure side hose I happend to get with the box, and after testing the plain fitting in the box alone to determine the proper direction for the tube to point, I nickle silver brazed the tube into the fitting. Now I have a tight right angle bend fitting that will let the hose clear the header pipe.
By the way in case you can use the info, the >1980 GM Saginaw PS pump uses the same 16mm fitting as the pressure side of the box does, so you can use a stock Toyota pressure hose! The return side is low pressure so you just use a cut to length PS return hose and a couple hose clamps for that line. Since I returned the hose kit to MF I decided to go top shelf with Russell brand SS braid covered PS hose and fittings from Summit racing to match the other braid covered hoses on the truck. Russell does make 16mm to 6 AN adapter fittings for the pressure side.
Old 12-24-2004, 02:27 AM
pootscratch pootscratch is offline
pootscratch is starting off with a positive reputation.
Walston,
I was wondering how you were going to approach the pitman arm issue?
Vern
Old 12-24-2004, 03:35 AM
AXracer's Avatar
Mid fifty and CCP sell a conversion pitman arm with the Toyota spline and ford draglink ball. I'd suggest getting a new pitman shaft nut as well.
Old 12-24-2004, 07:22 AM
Walston's Avatar
Pootscratch,
I have both the Toyota arm and the original. I plam to cut the spline ends off and weld the Toyota spline end onto the original Ford Pitman arm. I'll post a picture when finished.
Toyota Steering Box Identifier BigBlueCat 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-07-2016 07:34 PM
Toyota power steering upgrade and 4x4 Caveman2851 1957 - 1960 F100 & Larger F-Series Trucks 2 07-22-2015 07:38 PM
toyota steering box 69 f-100 aman 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-05-2015 07:01 PM
toyota steering box HILLBILLY BOB 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 04-11-2013 07:11 PM
1950 f1 steering box upgrade 1950 boy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-22-2009 11:15 AM
Tags
1986, 48, 4x4, 79, box, fittings, ford, funny, identify, installing, pressure, side, steering, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
