03 Expedition Rotor Removal - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-17-2004, 12:23 PM
FSU2Times FSU2Times is offline
FSU2Times is starting off with a positive reputation.
Thumbs down 03 Expedition Rotor Removal
Help!!!! Does anyone know how to remove the front rotors on the '03 Expedition. The Auto Parts store loanded us a slide hammer and that didn't do anything (although not from lack of effort).
I really want to do this replacement at home but have no clue how to get the old rotors off.
Old 12-17-2004, 12:36 PM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
For most a BFH has done the trick along with penetrating oil, torches, sawsalls, etc.
Somebody made a good suggestion once. Put the wheel back on and don't fully tighten the lugs then lower the vehicle and drive it a couple feet and let the weight of the vehicle do all the work.
Old 12-17-2004, 07:44 PM
saltzy saltzy is offline
saltzy is starting off with a positive reputation.
...or, you might have to bite the bullet and replace the whole hub and assembly because the rotors just won't come off. Of course, I don't think this will be your case since this was on my '01 when it was almost 3 years old. We banged used PB BLaster and did everything under the sun for 3 hours until we brought it to the shop where the mechanic/owner raised it for a better angle, hammered it for 2 more hours then used heat and they still wouldn't budge.
Lots of others haven't had it so bad. A few have resorted to using a sawzall and cutting them off in pizza-like wedges. Better than a mis-swing with the BFH and snapping off the little ear on the steering knuckle where the caliper attaches to. Not that that's happened to me or anything.
Old 12-19-2004, 09:49 AM
hoosier1985 hoosier1985 is offline
hoosier1985 is starting off with a positive reputation.
Angry Help with caliper bracket removal.....2003 EXPED
Help...I hate to sound like a big sissy...I've changed pads on other vehicles, BUT after fighting with 2 bolts for 1 hr (and winning), I couldn't get bracket off rotor. Is there something else to remove or are pads stuck to rotor? I tried to gently pry but wasn't sure.........2003 Expedition 4X4
Old 12-19-2004, 10:05 AM
Use a C-Clamp and push the piston back a little ways into the caliper. The caliper should come off pretty easily after that. If the pads were stuck to the rotor, the truck wouldn't move.
If you can push the piston far enough back, and the pads are worn out enough, you'll probably see them fall out of place and it should come right off.
Old 07-05-2007, 09:52 PM
cypherantidote cypherantidote is offline
cypherantidote is starting off with a positive reputation.
Thumbs up rotor removal
my method....
-borrow a 5 ton pull from autozone
-using a grinder with a 1/8'' edge, cut three designated spots on the lip of the inner portion of the rotor (depicted as red in the image below)
-set the pull up and start cranking
works like a charm everytime for me.
cheers!
Old 07-06-2007, 02:01 PM
AF Mezkin's Avatar
AF Mezkin AF Mezkin is offline
AF Mezkin is starting off with a positive reputation.
I recently replaced my rotos on my 03 Expy and ran into some trouble with the front rotors. What seemed to work for me was to remove the caliper and move it out of the way and spray WD40 around the center, around the bolt holes and from behind the rotor then let it sit for about 5 to 10 minutes. I then gave the rotor swift hits to the rotor INWARD to brake it lose, then I gave it light blows from the back going around the rotor until it starts to seperate. The first one took me around 30 minutes, once I knew what to do the second was done in half the time. Hope this helps out, good luck!
Old 07-06-2007, 02:08 PM
dakota_viking's Avatar
dakota_viking dakota_viking is offline
dakota_viking is gaining momentum as a positive member of FTE.dakota_viking is gaining momentum as a positive member of FTE.
Quote:
Very good advice! I've used this method before on many different vehicles and it has always served me well.
The inward blows will get things loosened up and then you can do the outward hits.
A little anti-seize around the hub when putting it back together never hurts either.
Tim
Old 07-07-2007, 07:08 AM
flyncasafo's Avatar
flyncasafo flyncasafo is offline
flyncasafo is starting off with a positive reputation.
I had the same problem on my 00. I soaked the rotors in PB Blaster for two days then whacked the crap out of them and still they did not budge. I had to use the Sawzall with three cuts into the rotors and they fell right off! I used tons of antiseize afterwards.
Old 07-07-2007, 09:49 PM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
This may be a silly question but is the truck 2wd of 4wd? If it is 2wd you problably have to remove the hub and rotor as one unit which in that case means releasing the front bearing.
Old 07-09-2007, 11:05 AM
racerock racerock is offline
racerock is starting off with a positive reputation.
Quote:
Good move, hopefully you have seen one of my posts on this. Sawzall is the way to go, it does not stress your front end at all.
Old 07-09-2007, 11:07 AM
Quote:
Originally Posted by cypherantidote
my method....
cheers!
It is stuff like this (and the other suggestions which include a 3 lb sledge) that crack me up. Why put all the stress on your bearings, ball joints, brake brackets, etc. Just to throw out the rotor.
If you have a wizwheel, sawzall, and a cold chisel, just slice the rotor, spread it with the cold chisel and cut the sucker off.
Takes about 10 minutes a side, with no stress.
Can we make something on this a sticky?
Old 06-17-2008, 11:01 PM
sclieu sclieu is offline
sclieu is starting off with a positive reputation.
Hi...I searched various places, and found various solutions to getting the front rotors off. Seems like depending on year and 2WD/AWD, it may be different. Can someone please let me know best way to remove front rotors for my SUV:
'04 Expedition with 2WD.
If I have to remove the hub and rotor, how do I do that? I got the calipers off and tried banging at it, but that did not seem to work. I've also heard of some folks advice (which used to work on my old car) where you used the sockets where the calipers are bolted to, and get a strong bolt, washer, and nut, to basically push out the rotor. Anyone tried that solution on the Expy?
Thanks!
Old 06-19-2008, 07:31 PM
Update on my question to hopefully help others. I was able to get the rotors out as follows:
1) I borrowed a 2 -ton puller from Autozone. It was a bit small, but I was able to adjust it to barely fit the rotor. I tried to get it out but it did not seem to budge. I left it there as I assumed it was still putting pressure on the rotor to come out.
2) I went and bought some bolts, nuts, washers and used the holes that normally hold the calipers in place, to push the rotor out. After turning the bolt a few times, the rotor popped out. It made a somewhat loud noise that startled me, but I was happy as hell.
In summary, I don't think I really needed the puller, but it did not hurt either. I'm going to change my other rotor and try it w/o the puller to see if the bolt trick works.
FYI, I never worked on the Expy before and it's a bitch to change the brakes. It took awhile to figure out how to fit the pads on, but now that I know, it's pretty simple.
Hope this helps others.
Old 06-21-2008, 06:36 PM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
I cut some OAK wedges and BFH ,and used behind rotor top and bottom after soaking good with WD40. One set of wedges for each side.
Front Brake Disc Rotors, Finding a Cure? Todd Fuller 1997-2006 Expedition & Navigator 5 12-31-2016 09:53 PM
Sway bar bolts/nuts & front rotors question Gage2502 1997-2006 Expedition & Navigator 6 06-10-2011 10:35 PM
Rotors on 2000 Ford Expedition campatuf 1997-2006 Expedition & Navigator 13 09-21-2009 08:02 PM
03 Expedition Door removal lkborg 1997-2006 Expedition & Navigator 5 04-26-2008 08:37 AM
2004 Brake rotor removal oldhokie Escape & Escape Hybrid 1 10-16-2007 05:27 PM
Tags
2003, back, brake, change, difference, expedition, ford, front, replacement, rotor, rotors, rusted, sawzall, type, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
