Truck Avenger - Ford Truck Enthusiasts Forums
Truck Avenger
Old 12-16-2004, 12:29 PM
Rigs84F150 Rigs84F150 is offline
Rigs84F150 is starting off with a positive reputation.
Question Truck Avenger Carb Problem
I have just purchased a Truck Avenger 670 for my F150 with a 302 and I am having a very bad sputtering, coughing and sometimes stalling problem off idle or on light acceleration. It starts good and has great power if you put your foot into it and get past the sputter. I have checked float levels, vaccuum spec's (19"), have the correct voltage going to the choke and have adjusted the idle mixture to try to solve this problem. I have read alot of postings (after i purchased this wonderful carb ) from people having similar problems and alot of them have had to change all sorts of things on their carb (jets, accel nozzels and pumps etc)...which seems like alot of fussing for a brand new carb which is suppose to be close to almost perfect out of the box. Any info or suggestings would be great.
Thx Rigs84F150
Old 12-16-2004, 05:44 PM
Sanders's Avatar
Sanders Sanders is offline
Sanders is starting off with a positive reputation.
I haven't had any experience with the truck avenger, but the Street avenger series are fairly reliable. I have a 570 Street avenger on my 331 stroker and it pulls like a runaway frieght train. Some have told me I'm a little undercarbed but I'm only giving up a little top end. Holley's are bad tempered though.
Holley's for the track, Edelbrocks for the street.
Sanders
Old 12-16-2004, 11:36 PM
Sanders,
Thanks for the info... I was talking to a local ford guru today and his suggestion was to return the Truck Avenger 670 (being to much carb for my little 302) and get myself a Street Avenger 570 or if I have the bucks get a Road Demon 570. I also talked to Holley's tech line and they suggested that the Truck Avenger 670 is sometimes to much carb for small blocks and suggested getting a Street Avenger 570. The new carb is on order and I should have it installed in the next couple of days. I will keep everyone posted.
Rigs84F150
Old 12-17-2004, 03:58 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
670 CFM is big enuf for a 460, way too big for a 302.
Old 12-17-2004, 01:32 PM
95 F150 95 F150 is offline
95 F150 is starting off with a positive reputation.
Unless it is a boss 302 j/k
Old 12-19-2004, 03:55 AM
Torque1st's Avatar
Posting Legend
670 CFM would run a 302 to nearly 8000 RPM at 100% VE according the Holley charts. Their directions say to use a SMALLER carb than the chart shows also. For a 302 use a 450 CFM or smaller carb. I usually use 1.5 x cubes to figure the MAX size carb for a street engine.
Old 12-19-2004, 01:50 PM
Thank you for your advice. I installed the street avenger 570 yesterday and the stalling problem is gone. The carb works great with that motor. One thing, when going up a long hill at a continuious speed the engine starts to ping now. Would this be an indication that the carb is running to lean, causing the combustion chambers to over heat?
Old 12-20-2004, 12:20 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Yes, itis possible. You might double check the timing. Maybe back it off 1 or 2 degrees and see if it goes away.
Need help on cold weather applications for my truck Old red 1986 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 04-07-2015 11:09 AM
429 Carb and Intake ? 429 FORD POWER Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-09-2009 11:44 PM
408 sputters at high RPMs TheBlueMule 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 17 11-15-2008 11:40 PM
Holley Truck Avenger 770 for 460? oldmansimek Fuel Injection, Carburetion & Fuel System 10 02-22-2005 10:39 AM
Holley Truck Avenger Carbs any good? bigpoppax2 Offroad & 4x4 1 11-04-2004 08:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
