Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 12-16-2004, 12:54 PM
Whaler Whaler is offline
Garage is empty, add now
Whaler is starting off with a positive reputation.
Question Pulley Dimensions?
What are the dimensions of the upper and lower blower pulleys on an 02' Lightning and do you measure them from the outside edge of the pulley. I just bought this truck used and the boost is 10 lbs. I thought that 8 lbs. was the max. The truck appears to be stock.
  #2 (permalink)
Old 12-16-2004, 04:09 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
The stock gauge isn't very accurate and the boost you get will vary a lot depending on weather conditions.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #3 (permalink)
Old 12-17-2004, 05:00 AM
sigma's Avatar
sigma sigma is offline
sigma is starting off with a positive reputation.
The stock crank pulley is 7.5 inches and the stock blower pulley is 2.93 inches. As mentioned the factory boost gauge is not very accurate.
__________________
The point of life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn out, screaming "....HOLY ****!....WHAT A RIDE!
  #4 (permalink)
Old 12-17-2004, 07:55 AM
Do I measure outside edge or from the grooves of the pulley?
  #5 (permalink)
Old 12-17-2004, 12:55 PM
nthe10s nthe10s is offline
nthe10s is starting off with a positive reputation.
From the outside edge - the lower is 7 7/8" , the upper is 3 1/4. The lower is most commonly changed. And yes the factory boost gauge often reads to 10lbs.
Hope this helps.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
