03 Expedition typical problems?
Whining rear diff.
Whining front diff.
Crappy brake pads. Well...they stop fine, they just dust a lot.
Crappy tires.
Limited slip problems in some (not mine though)
Doors rattling. (Driver's side in my case) TSB issued to "solve" problem.
Body cladding fading. Can be replaced under warranty.
Will not "peel out" on dry pavement because it is an overweight, underpowered soccer-mom mobile. I still like mine though...I like Christopher Titus wife's truck better.
Whining front diff.
Crappy tires.
I purchased a 2003 Eddie Bauer Expedition 5.4 V8 in August of 2002 and I have had the door rattling but that was fixed with a Special Service Bulletin that I just happened to find, not a TSB. I also had the reverse mirror problem and that was corrected with a TSB. Other than that, my Expedition has been great. I also haven't had the whining problem in the rearend or the front and I haven't had the cladding fading because the Eddie Bauer tan cladding doesn't fade like the XLT black cladding, not sure why, but it doesn't. My brakes also do not produce huge amounts of brake dust like most peoples either. As a matter of fact, my '03 hasn't had as many problems as my friend's '04. All in all, I love my Expedition and if I had to trade right now, I would get another Expedition. I say go for it.
Here is the TSB regarding the reverse tilt mirrors, I think this only calls for the memory module to be replaced, however, if this doesn't correct the problem, the mirror motors need to be replaced because the gears were more than likely stripped when the mirrors were popping at the extremes.
Make : FORD Model : EXPEDITION Year : 2003
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Num : 16675 Date of Bulletin: MAR 01, 2003
NHTSA Item Number: 10001933
Component: VISIBILITY:REARVIEW MIRRORS/DEVICES
Summary:
REVERSE TILT-DOWN MIRRORS NOT RETURNING TO THE PRE-REVERSE POSITION AFTER SHIFTING TO REVERSE AND THEN TO DRIVE. *TT *JB
Summary:
