Engine......HELP!!!!
well guys and gals...I blew my engine in my 75 f250 today.....It swallowed a valve and smacked through the piston....on another cylinder, the lifter was pushed up and out of its home(dont know where it went)...the pushrod screwed the cam all up, Somehow the head gasket took a dump too...basically....I need a motor!...Anyone in ny that has a mill for this beast?
It has a 390 in it now with a 4 speed manual trans...will a 351m or a 360 bolt up in this?....If anyone has a motor for sale LEMME KNOW PLEASE!!!
thanx again,
rob
If anyone needs any "HONDA" advice lemme know....hahaha
thanx again,
rob
I have a 351M or a 400m that will work,you will just need to change the motor mount perch's.I have the bellhousing,Brandnew clutch pak,and flywheel.It's in upstate NY.$400. for mill,and bellhousing,and part's.I also have the perch's for the 351M/400M.The 360/390,and the straight 6 use taller perch's,and won't work.Please let me know couse im doing a winter clean up so I have some where to pile snow,and I can get my land lord off my back(LOL)..
