Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New York Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New York Chapter Join Chapter, Leader: tiny1
Closed Thread
  #1 (permalink)
Old 12-15-2004, 08:42 PM
winterx700 winterx700 is offline
Garage is empty, add now
winterx700 is starting off with a positive reputation.
Engine......HELP!!!!
well guys and gals...I blew my engine in my 75 f250 today.....It swallowed a valve and smacked through the piston....on another cylinder, the lifter was pushed up and out of its home(dont know where it went)...the pushrod screwed the cam all up, Somehow the head gasket took a dump too...basically....I need a motor!...Anyone in ny that has a mill for this beast?
It has a 390 in it now with a 4 speed manual trans...will a 351m or a 360 bolt up in this?....If anyone has a motor for sale LEMME KNOW PLEASE!!!
thanx again,
rob
If anyone needs any "HONDA" advice lemme know....hahaha
  #2 (permalink)
Old 12-15-2004, 08:55 PM
fordfury469's Avatar
fordfury469 fordfury469 is offline
fordfury469 is gaining momentum as a positive member of FTE.
boy does that suck i have a ton of 360/390 parts laying around.
  #3 (permalink)
Old 12-15-2004, 09:13 PM
supercab4x4dually's Avatar
supercab4x4dually supercab4x4dually is offline
supercab4x4dually is starting off with a positive reputation.
I have a 351M or a 400m that will work,you will just need to change the motor mount perch's.I have the bellhousing,Brandnew clutch pak,and flywheel.It's in upstate NY.$400. for mill,and bellhousing,and part's.I also have the perch's for the 351M/400M.The 360/390,and the straight 6 use taller perch's,and won't work.Please let me know couse im doing a winter clean up so I have some where to pile snow,and I can get my land lord off my back(LOL)..
__________________
1979 Supercab 4X4 460/C6
1979 F350 4X4 Dually351w
1979 Bronco T/Special 400/C6/N.P.203
Edited by FTE
List Mod's & other Equip in Gallery
  #4 (permalink)
Old 12-15-2004, 09:44 PM
Quote:
You have a message!
Closed Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
