door rattle
I have an FX4 Screw and get teh same like poping noise. I thought it may be the locking mechanism where the fron door catches the latch and maybe it needed to be adjusted in. I took it in and they said tehy tightned the blts and less than 1K miles later it is back. I will check the front door hinge. I thought about adjusting the latch in to see if this helps too. Thanks for the info and if anyone finds other fixes let us know,.
I checked mine out yesterday. The hinges are fine but I did notice something different on the drivers side. when I looked at the door lock on the door you will notice at the back of the indention a sort of bump. to hold the door firmly against the lock. Any way I noticed that it was actually cracked and when I simualted the door latch pushing against it you could see it flex and the crack would open. So I think the popping I may hear may in fact be that bottoming out in the back. After teh holiday I am going to take it in and show it to my local shop and see there thoughts. By the way I compared it to the other four doors and this is the only one that was doint it and it just happens to be in the acutal area that I hear the noise from. I hope this is it for that would be an easy fix and the relief of a major headache. I love this truck, and that is something I thought I never would say being that I was a huge Toyota fan for many years. This truck ranks up there with the first Toyota I owned and for my family to hear me say that, they were impressed. Hope this helps any of you out and if you find something different please post.
Have a good holiday!!
I had the same rattle in my door. The dealer had to adjust the latches. Also, when closing the rear door try shutting it hard. My truck latches on the bottom but the top latch only catches a little if closed lightly and it will rattle. If closed hard, the top latch catches fully and there is no rattle. You can tell if is not fully latched by looking at the weatherstrip at the top of the rear door when closed.
I have a rattle only on the drivers side rear door on my scab. I can close the doors on the passengers side and there is no noise. Working on the drivers side close the rear door and then closing the front door the rear door has a rattle. When I go in for my next oil change I'll let them know. I really hear the rattle when going over rough terrain like every moring when I go through the parking lot at work its really bumpy.
