Truck Starts Hard, Then Dies - Ford Truck Enthusiasts Forums
Old 12-15-2004, 12:49 PM
websthes's Avatar
websthes websthes is offline
websthes has a great reputation on FTE.websthes has a great reputation on FTE.websthes has a great reputation on FTE.websthes has a great reputation on FTE.
'90 302 efi.
truck starts hard... when i get it going i have to keep my foot on the gas, make high rpm's so it won't stall. after a minute or two the truck always dies. my brother in law thinks it's a fuel problem. that its just consuming hte fuel left in the line. but the pump worked good when i changed the filter. i'm thinking it's the pressure regulator. called the parts store started getting prices from 60 to 160$ CAN.
looked on ebay.. there's nothing for ford trucks but they sell a lot of parts for 86-93 5.0 mustangs... will the part work? where else can i order one. lot of places don't like to deliver to canada either
Old 12-16-2004, 10:59 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would check the fuel pressure before I bought anything, It should be between 32 and 40 PSI.
Did the distributor move and slow the tining way down? Have you checked for vacuum leaks? Make sure that the vacuum line to the MAP sensor is good or it will flood itself out.
Does it smell rich? Black smoke?
Old 12-17-2004, 10:37 AM
websthes's Avatar
i already bought one. we were down in new york so i got one at autozone for 19$. a gp sorensen brand. feel better just knowing i have an extra one.
i'm going to look at the vacuum hose like you say. don't really know what i'm looking for but i have the chilton book.
Old 12-18-2004, 10:44 AM
websthes's Avatar
i can get it to start the first time... runs nice for a minute then dies... then it won't start again and when it does it runs really bad, stumbles, makes a lot of smoke, then dies
guess the fuel system is out of whack.. found the red plastic line goes from the fuel pressure reg to the top of the manifold. from there's rubber lines going all over the place. hoses look OK but don't really know what to look for
oh and i cleaned the iac with carb cleaner and put it back in. should i unplug the battery for a bit to reset the computer?
i put a tester on the valve in the fuel rail. one turn, five turns of the key, pressure comes up 22 each time
Old 12-18-2004, 04:11 PM
jdhudall jdhudall is offline
jdhudall is starting off with a positive reputation.
I would check the MAF MASS AIR FLOW SENSOR because my 98 ranger did the same exact thing it would start up hard and only run for a minute or less and then die! I thought it was the fuel also but that wasn't the problem if you know of some one with a truck like yours just swap out the MAF sensor and try that if it doesn't work than at least you won't waste any money I just barrowed one from my neighbor and the truck started right up and ran fine!!
Old 12-18-2004, 05:38 PM
LxMan1's Avatar
22 is low on the fuel pressure, it should come up to around 40 when you turn the key on a couple of times.
Hard to start and engine dying when running? catherf-350 1999 to 2016 Super Duty 1 02-28-2013 06:02 AM
Truck dies while at idle and then won't start The Lawnman 1994.5 - 1997 7.3L Power Stroke Diesel 16 07-09-2012 10:29 AM
Fuel back pressure? ErinsFord 1987 - 1996 F150 & Larger F-Series Trucks 3 06-23-2012 02:55 PM
Fuel system problem jhkfarms 1994.5 - 1997 7.3L Power Stroke Diesel 13 07-21-2009 06:30 PM
recall #95S28 FyreLyter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-05-2004 03:33 AM
Tags
302, 50, 86, dies, f150, ford, fuel, hard, injected, minute, runs, slowly, stars, start, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
