Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 12-15-2004, 06:19 AM
NSTAG8R NSTAG8R is offline
Garage is empty, add now
NSTAG8R is starting off with a positive reputation.
Leaking Fuel
I hope someone can help me with my problem. First did a search and could not find the same problem I am having. Here goes, on cold mornings I start my truck and let it warm up. I have noticed a pool of diesel has formed on the ground underneath the truck. I checked to see where it is leaking from, no question about it, it is leaking from the drain tube that is attached to the fuel bowl. Could there be a o-ring in the drain valve that constricts in cold weather and allows it to leak. I have checked the tube once the truck warms up to operating temperature and no leaks are visible.
If anyone else has had this problem, please share with me your solution. I feel the need to take the drain valve off and replace the o-ring, but do not want to go into it blindly
My truck is a 1999 F-350 Superduty with a 7.3L, 104,000 miles on it.
http://community.webshots.com/album/214337536vWQdvN
  #2 (permalink)
Old 12-15-2004, 09:03 AM
Stump Jumper Stump Jumper is offline
Stump Jumper is starting off with a positive reputation.
I got the same problem. It only does it in cold weather.
  #3 (permalink)
Old 12-15-2004, 09:16 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
I've never done it myself but you can remove the drain valve and go up to the local hardware store and buy the correct sized o-rings, replace them and have your problem fixed. There's lots of people on the board here who have written in and said that.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #4 (permalink)
Old 12-15-2004, 09:27 AM
Quote:
Thanks Kwikkordead, I will check into that later this week. Do not know much about diesel stuff, but if I own one I guess I will have to learn about them. Was searching other places on th WWW and found this thread:
http://www.dieseldoctor.com/messageboard/data/552.html
  #5 (permalink)
Old 12-15-2004, 09:35 AM
What about simply caping off the drain tube? Of course one would have to remove the cap when ever you need to drain it, then simply cap it off again. Or possibly installing some kind of valve at the end of the tube.
  #6 (permalink)
Old 12-15-2004, 01:20 PM
Max1775's Avatar
Max1775 Max1775 is offline
Max1775 is starting off with a positive reputation.
Exclamation
I definitely would not suggest capping the drain line. The fuel bowl is under high pressure when the vehicle is running and it will probably blow the hose off if done that way. Change out the oem valve or o-rings and save a lot of headaches in the future.
__________________
97 F250 PSD, 3.55 ls, 4" exhaust, K&N FIPK, Autometer gauges, DP Tuner PCM, Propane Injection, STS Tranny, KB audio, and more...
  #7 (permalink)
Old 12-15-2004, 01:41 PM
Thats what I am going to do, fix the o-ring problem
  #8 (permalink)
Old 12-16-2004, 04:48 AM
1999 Ford F-550
Quote:
It would seem to me to be a lot easier and less work to just fix the drain valve.
__________________
Dan
  #9 (permalink)
Old 12-16-2004, 01:32 PM
semperfipsd semperfipsd is offline
semperfipsd is starting off with a positive reputation.
Just replaced my valve two weeks ago. My diesel mechanic said if I have to go some where prior to fixing it I could plug up the tube for a temporary fix but still would have to fix the valve as soon as I got the parts. Ford only sells the the valve and o-rings as unit, even though they do list the o-rings as a seperate part number. After I took my valve off (be prepare to get real up close and personal with the top of you engine) I had to lay on top of it for about a total of an hour/hour and half. Anyway, I couldn't see how just replacing the o-rings would have helped my problem. If I blew on the valve in either the on or off postion it allowed air to go through the valve. To me it looks as if the o-rings are only for sealing the valve to the filter body. Once I had the new valve installed no more leak and I was good to GO! The valve cost me at Ford $31? Had to wait one day because my local dealer doesn't stock many parts. To remove the valve all I had to do was plastic engine cover on top of the engine, move one harness bolt so the harness in the back could be moved farther out of my way, and removed the drain tube from the vavle prior to removing the torx screws. Yes, screws! there are 4 little torx screws holding that small valve on. It would really help to have a stubby torx driver if possible. I had to make do with a 1/4" drive ratchet and socket with a torx bit stuck in the socket. Then I was only able to get a few clicks of the ratchet per turn, a very slow process.
  #10 (permalink)
Old 12-16-2004, 01:39 PM
Well now I will know what to expect when i go to fix the problem. Thanks.
Have you ever been to MCRDPISC, Semperfipsd?
  #11 (permalink)
Old 12-16-2004, 03:55 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
This is actually a pretty straightforward fix-it-yourself project. It should take you about an hour after you get the parts and proper tools.
Before you change anything, turn on your key to pressurize the system. Locate the small, yellow-handled fuel filter water drain valve on the firewall side of the fuel filter. Exercise this valve a half dozen times. Maybe you'll get lucky and blow out the cause of the leak. Otherwise:
You need:
1. A #20 Torx driver socket for 1/4 inch drive.
2. A 1/4 inch ratchet
3. From Home Depot's plumbing department, two #90 Danco o-rings. If you don't have a H-D local to you, they're 1/2" od, 1/4" id, 1/8" material, available from most hardware stores.
Optional: Proper size socket and ratchet for removing the "Powerstroke" plastic cover from the top-front of your engine.
For ease, remove the "Powerstroke" cover.
Locate that yellow valve handle at the side closest to the firewall. This is the drain valve. Remember how the pieces are oriented for later re-assembly. Better yet, take a digital picture. There are four #20 Torx screws holding the valve to the filter body. Using the driver socket and ratchet, remove the four screws. Using a toothpick, pry the two little yellow o-rings out of where they fit. Replace them with the two you bought. Lube the threads on the four screws. Re-assemble and check for leaks. Replace the Powerstroke cover.
Dat's all, folks.
SpringerPop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks, and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, spin-on hydraulic filter, coolant filter, 6637 & cover, bypass lube oil filter, HPX, Hutch n' harpoon.
Email SpringerPop SpringerPop's F-350
  #12 (permalink)
Old 12-17-2004, 02:19 AM
Nstag8r, Nope never made it over to the sandpit I'm a hollywood marine! was stationed in the armpit MCLB Albany, Ga one time! Good luck on the repair.
  #13 (permalink)
Old 12-17-2004, 07:34 AM
thanks Springer and all.
  #14 (permalink)
Old 12-17-2004, 08:47 AM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
i had to replace the drain on my 2000 it was $35
it was squirting down into the engine valley
  #15 (permalink)
Old 12-17-2004, 11:36 AM
2000 Ford F-350
To EDIT my post, #11, above:
Danco customer service tells me that their o-rings are not made of buna-N, but plain 'ol buna, which is not the best choice for fuel applications. I will be getting some different o-rings through McMaster-Carr that are designed to better stand up to fuel.
Thought I better alert you all so I don't lead you down the wrong path.
SpringerPop
__________________
Tags
2003, 73, diesel, drain, f250, ford, forums, fuel, kind, leak, orings, powerstroke, problems, replace, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
