Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 01-29-2007, 09:42 PM
Idagrizz Idagrizz is offline
Idagrizz is starting off with a positive reputation.
This forum saves me so much money . The stealership here wants 66 $ for the valve and 130.00 to install. Think I'll order the orings and do it myself . This is on top of the 900$. to replace the glow plugs and relay at 20$ apiece for glow plugs and 140$ for relay plus labor. Funny I had already talked to their supplier they only wanted 8$ for the plugs and 40 $ for the relay . Thanks all for saving me money again .
  #32 (permalink)
Old 01-30-2007, 04:43 PM
scwirenut's Avatar
scwirenut scwirenut is offline
scwirenut is starting off with a positive reputation.
Well I got mine (o'rings) in the mail today, 1 hour later , NO MORE LEAKS , yee haaa!....the biggest problem I had was getting the valve loose from the drain tube (no room).thanks everyone
  #33 (permalink)
Old 01-30-2007, 05:43 PM
badger2196's Avatar
badger2196 badger2196 is offline
badger2196 is starting off with a positive reputation.
I had a leak with similar symptoms and it turned out to be the o-rings on the drain valve. I had the good people at Colorado Diesel fix mine (they have a heated garage ) but they have seen a lot of these recently and put it down to the ultra low sulfur diesel introduced last year. Most people don't seem to think ULSD will affect injector seals though.
  #34 (permalink)
Old 01-31-2007, 01:16 AM
rajujaini rajujaini is offline
rajujaini is starting off with a positive reputation.
Thank You
Greetings All! I just wanted to take a moment and say thank you VERY much for all of the info... A couple of days ago, I was doing some errands and noticed that my F350 was leaking something... I freaked out when I realized that it was Diesel Fuel! I was in a grocery store parking lot and it was Sunday, so I tried isolating the problem, and noticed that the gas would leak when I turned the key to the "wait to start" position... if the truck was off, no diesel leaked... I noticed a tube from the passenger side wheel well hole that was actually leaking the fuel...
I went out, bought a Haynes manual, chilton's online manual, and couldn't find anything... I was sure that this tube must connect to something, but could not find where it connected to... I couldn't even find the name of the part I was looking at!
I found this forum and did the separator drain valve replacement thing... I say thing because while I own a construction company, I don't know the first thing about mechanics. With everyone's guidance, and some time (about 5 hours), I was able to remove the turbo diesel cover, take off the 4-T20 screws, replace the O-rings (with fuel rated O-rings), put the drain valve and yellow handle thing back, and even though I still can't figure out why it worked, it did!!! I did this in the parking lot of the grocery store, not only saving myself a huge repair bill, but a huge towing bill as my F350 is lifted.
Thank You once again for helping me solve this problem, and getting my interest peaked in toying with my truck!
R.J. - 1999 F350, Crew Cab, 7.3L Diesel, Dually, Lift Kit, Banks Package
  #35 (permalink)
Old 12-16-2007, 05:40 PM
Jim Rowley's Avatar
Jim Rowley Jim Rowley is offline
Jim Rowley is starting off with a positive reputation.
From the date of the last post, it seems that no one is having trouble with their fuel bowl valve, except me. I ordered some o-rings from McMaster Carr but I don't really need 25. If anyone needs a couple, send me an email and I'll mail them out to you. I just did thirty unnecessary miles because the NAPA parts guy lied to me. I called for the o-rings and he said "yeah, we have them". Big fat LIAR!!!
Thanks to Pop and everyone that pointed me in the right direction with this thread. This forum is awesome.
Jim.
  #36 (permalink)
Old 12-17-2007, 09:18 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
I'm of the opinion that the leaks are not caused by torn o-rings, so much as grit getting caught underneath the o-rings.
I've had a drip or two before and fixed it by cycling the valve several times.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #37 (permalink)
Old 12-17-2007, 09:36 AM
Jim Rowley's Avatar
I cycled the valve so many times, I think I wore the o-rings out. Oh well, if the o-rings are still good, consider a stocking stuffer for the truck. It's been good to me, what's a couple of o-rings and a GPR and...
Jim.
  #38 (permalink)
Old 12-17-2007, 08:27 PM
PolarBearKing PolarBearKing is offline
PolarBearKing is starting off with a positive reputation.
This is such a common prroblem I don't know why Ford doesn't recall it.
All it is going to take is one vehicle fire where someone gets burned (Heaven forbid) and they'll lose any saving they claim by ignoring an obvios problem.
  #39 (permalink)
Old 12-19-2007, 11:26 PM
Jim Rowley's Avatar
I just replaced the two o-rings and cleaned everything before reinstalling the valve. BUT if you really want to totally overhaul the valve, you should replace the smaller o-ring that seals the internal ball assembly from the outer housing. Only if I had known about it, I would have ordered some of those too. Instead, I cleaned it and squirted it with some carb cleaner to make it swell up a little. so far so good. BTW, those two o-rings were as flat as a pancake.
Jim.
  #40 (permalink)
Old 12-31-2007, 02:51 PM
SueEmAll SueEmAll is offline
SueEmAll is starting off with a positive reputation.
Quote:
Jim.
Jim, I got the o-rings in the mail today. I figure I will tackle this project tomorrow with a hangover. Thanks!!!
  #41 (permalink)
Old 12-31-2007, 05:40 PM
IDPisan's Avatar
IDPisan IDPisan is offline
IDPisan is gaining momentum as a positive member of FTE. IDPisan is gaining momentum as a positive member of FTE.
Here is a good link for repair and replacement.
http://home.centurytel.net/sabre/drainvalve.html
__________________
My two cents, Jeff
Early 99 F350 4X4 CC DRW 6spd. 6637, MKO 4" turbo back 5" straight piped exhaust 6" tip, ISSPro Gauges, Pyro, Boost, Water temp, DP Tuner Stock, 40tow, 60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator, Auto Enginuity, GPR LED Indicator. 6.0 intercooler, CCV mod, EBPV delete,Wastegate Mod. 320,000 miles and counting.
  #42 (permalink)
Old 01-26-2008, 06:21 PM
I finally had to do it, only problem is, is that I still have a leak.
I took my time and made sure everything was put back together snug.
If it makes any difference, my gaskets where not flat, cracked or torn.
Any other suggestions?
  #43 (permalink)
Old 01-26-2008, 06:28 PM
Jim Rowley's Avatar
Did you pull the inner part out from the valve body? It comes out if you twist it and line up the flat sides. I cleaned the o-ring in there too. I should have taken pictures. Duh.
Jim.
__________________
Jim Rowley
Colorado Springs, CO
2005 F150 FX4 SCrew
2003 Ranger 4x4 5-sp, sold
1999 F250 4x4 6-sp, sold
  #44 (permalink)
Old 01-26-2008, 06:32 PM
Jim.
I did not. I spun it around a couple of times and cleaned it up, but did not pull it apart.
  #45 (permalink)
Old 01-26-2008, 06:52 PM
Jim Rowley's Avatar
I would pul it all apart. That's where mine was leaking from. It turned out to be a lot of grit, even under the o-ring. I'll bet you two new o-rings that it will stop the leak by cleaning inside the valve.
Jim.
__________________
Jim Rowley
2005 F150 FX4 SCrew
Tags
2003 , 73 , diesel , drain , f250 , ford , forums , fuel , kind , leak , orings , powerstroke , problems , replace , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
