1965 ford f100 T85N - Ford Truck Enthusiasts Forums
1965 ford f100 T85N
Old 12-14-2004, 09:19 PM
zebrastud57 zebrastud57 is offline
zebrastud57 is starting off with a positive reputation.
1965 ford f100 T85N
i need parts for my T85N overdrive transmission, i need all the help i can get, mainly i don't have a repair manual or parts for the overdrive.
Old 12-14-2004, 10:20 PM
mikeescott mikeescott is offline
mikeescott is starting off with a positive reputation.
Is T85N same as T85?
I have a T85 I pulled out to put in the C6. Let me know if you need anything.
Old 12-14-2004, 11:26 PM
jav409 jav409 is offline
jav409 is starting off with a positive reputation.
What parts do yo need ? The sol rarely goes bad it's mostly just contat problem, other things like relays can be replaces with more current parts.
It is a electrical ot mech problem you r haveing.I can send you a wireing diagram if you message me with a e mail addy. And having just gone tru the electrical side of mine I would be happy to pass on what I have found.
mikeescott, let me know how you C6 works out please.
Old 12-15-2004, 03:06 AM
thanks
i have a wiring diagram, i really looking for a source of new parts or a source of a whole overdrive transmission or maybe just some of the overdrive parts. is the overdrive that you replaced all good mikeescott? and would you sell it all. i really need a assembly diagram or a rebuild instructions.
Old 12-15-2004, 06:19 AM
Mine had no overdrive.
It is just the 3-speed.
Old 12-15-2004, 08:28 AM
You might give these people a call, i have herd they overhaul these trany's
so they must have parts.
http://www.txchange.com/
Old 07-16-2006, 12:24 AM
rrise rrise is offline
rrise is starting off with a positive reputation.
Try Northwest in Ohio. I couldn't get the cluster gear for a T85n, it's unavailable but they had all the seals other gears bearing gaskets. I had to grind on some cluster gear teeth but was able to make it work fine.
Northwest Transmission Parts
13500 US Route 62 Winchester, Ohio 45697Toll-Free: 800-327-1955
Information Line: 937-442-2811
Fax Line: 937-442-6555
Warner T85N Garristotle 1967 - 1972 F-100 & Larger F-Series Trucks 10 12-01-2013 08:11 PM
Advice on T85N Borg Warner Manual 3 speed Overdrive Daboy 1961 - 1966 F-100 & Larger F-Series Trucks 0 09-03-2013 09:37 AM
1970 F100 302ci - 3-speed trans swap for T85N O/D dscheel 1967 - 1972 F-100 & Larger F-Series Trucks 0 08-03-2013 01:29 PM
Transmission swap questions - 3spd OD batboy 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-26-2003 01:23 AM
3 sspeed overdrive larryejoh 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-30-2003 10:50 AM
Tags
1965, 65, case, f100, f150, fix, ford, manual, overdrive, repair, service, t85n, transfer, transmission, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
