09-13-2000, 07:35 PM
96 Ford Ranger 2wd- vibration
I've noticed similar problems with my 97 4.0L 2WD, although not quite as quickly as yours. I've had two mechanics tell me it is due to the suspension the 97 and older Rangers have. According to them, the suspension chops the tires up, and gets them off balance. When I had on a pair of BFG AT tires, it was the worst. Essentially, you could see that the tires wore unevenly on the front two. I have to rotate them much more often than normal to keep it from vibrating. I've had quite a few alignments and so forth, but none of them have helped much. Makes some sense to me, the most I've been able to keep a set of tires on it is for 29,000 miles (17,000 for the BFG ATs) and I don't peel out or abuse them. Hopefully that will help give you something to look into.
