ignition Module 86 Ranger
I had many problems with the TFI module on my 85 Ranger I used to own. I think I replaced 2 or three of them. I think there may have been a recall after I got rid of mine, so you might want to check into that.
As far as diagnostics, I think you need an electronic diagnostic tool to be able to tell for sure if it's bad. But when mine went bad, symptoms were that first at higher speeds the engine started skipping, then idle went bad, and started stalling at low speeds. Finally it would just quit.
All in all, that was a horrible truck. It had the 2.8l V6 and I had nothing but problems with all the emissions valves and sensors. Much happier with my 96 4.0 XLT! (Knock on wood..)
Good Luck.
Good Luck.
eladnermai
06-08-2022 10:29 AM
hatchet
11-05-2007 06:13 PM
farmnaggie
03-07-2006 08:44 AM
tangcoral2004
04-23-2005 07:06 AM
