I have a 92 2.3 L Ranger too and i spliced the tach wire into the black/yellow wire coming from the bottom plug on the DIS module which i think is between the intake and the brake booster.
Welcome to the only family Ford Truck site, on the net. As you can see the members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
