04 shuts off at stop signs
#31
Mine was doing the stall as well. First trip to the dealers they found a "Vacum leak and dirty spark plugs" I don't know how the plugs can be dirty at 24,000 KM butttttt.... Anyway it ran good for 1 day then started stalling again at stops. Second trip to the dealer and they replaced the throttle positioning sensor. Since then (about 3 weeks) it has been fine.
#33
Originally Posted by ATVer1992
I dont own a newer f-150 but i am gona offer my .02
does it start to idle low when it stalls? what if you tap the pedal, will it keep running? Is the tranny not downshifting as you come to a stop, causing the engine to run to slow? Try shifting into neutral and comming to a stop. I'm guessing it may be something in the variable timing as the engine drops to idle speed. How about if the engine is warm (after driving it) and with it in neutral rev it to 2500rpm, hold it, and then take your foot right off the petal. Does it idle smoothly right away or does the idle drop too low and then stall or fluctuate while running rough. If it is a problem with the throttle fly by wire it should fail under this test. Let me know what you guys find.
During the problem, I noticed the rpm drop and fluctuate a little like if it is resisting further drop, but rpm goes back to normal when I change it from D to N.
#34
Winter, summer, compressor off, compressor on, at my first stop sign, 700 feet away from cold start, the engine MAY die when I attempt to move away from the stop sign. The ------- has been flashed, several times. The mass air flow sensor? has been replaced. The throttle position sensor has been replaced. What is next, the disgronificator? Ha!
#38
I have the exact same problem, as i come to a stop light my rpm's will tend to drop to around 350 ish and most of the time will stall. its happend about 12 times, i have had the truck for 3 months and only had 60,000 km's on it. it runs awesome at high speeds. very very rough idle when at a stop light and at low speeds. had it serviced at the dealer they cleaned the throttle body, and replaced the mast air sensor and tht didnt resolve the problem it still stalls. any idea?
#39
Stalling problem
I'm lucky enough to have a friend who's a Ford mechanic. He replaced my throttle body and that fixed the problem. He said that you're not supposed to clean a throttle body. Most people clean it with carb cleaner or an equivalent and it strips off a coating on the throttle plate, keeping it from closing properly. If your truck is under warranty, it shouldn't be a problem to get it replaced. If it's out of warranty, I'd see if there was a TSB issued for it and make them replace it.
#40
Thanks Larry, i apreciate your answer. Today i just got my whole throttle body replaced, sensors and all. But for some reason they did not reflash my Computer....is reflashing my computer a must? i mean the idle seems no different to me, still hovers around 500 hundred and when i come to a stop it goes below 500. please let me know if i should get this reflashed, i didnt get the throttle body done at ford i got it done with another machanic but can any shop reflash ford computers? thanks guys
