Magnatized Alternator Kills Battery - Why? - Ford Truck Enthusiasts Forums
Old 12-13-2004, 08:42 PM
mallman mallman is offline
mallman is starting off with a positive reputation.
I have a 1996 Ford F-150 with 105K miles. It is the best truck I have ever had. this year while driving I noticed the voltmeter dropping off, the truck sputtered and eventually died. Sears replaced the alternator and the battery. Six months later, the battery is dead again. Today four months later, I die at a gas station and even with a jump it is dead. I towed the truck in AGAIN. They can't understand it but the alternator is magnatized, the battery dead and the starter (a Sears re-built) dead.
What is causing this? I've never heard of such a thing. The only other anomoly is there is a 15 amp fuse that controls the speedometer, dome light and chimes that continually blows out every few months. HELP
Old 12-14-2004, 01:03 AM
t_dickie t_dickie is offline
t_dickie is gaining momentum as a positive member of FTE.t_dickie is gaining momentum as a positive member of FTE.
When is the alternator magnetized, and what part is magnetized? If the key is in your hand and the pulley is magnetized, then the alternator has a draw in it, probably caused be a bad diode. I'd get a new alternator and that should fix it.
Trevor
Old 12-14-2004, 04:45 PM
qman qman is offline
qman is starting off with a positive reputation.
Don't let Sears work on your vehicle. 10-15 years ago I bought tires from them twice and both times when I picked up my vehicle they had a list of things I needed that I knew I didn't. They assumed I was an idiot and would have them jump on it. Then 60 Minutes does a story on how Sears routinely rips folks off by making up things that their cars need. I haven't been back since. I'm sure its not as bad as it was but I wouldn't take my car to Sears for repairs. You probably got a bad alternator from them.
1999 7.3 upgrading to 2003 reduction starter fast_st 1999 - 2003 7.3L Power Stroke Diesel 29 07-09-2015 05:18 PM
Charging problems SleeprLegend 1987 - 1996 F150 & Larger F-Series Trucks 4 10-25-2014 08:41 AM
1996 Ranger JakeAnderson329 Ranger & B-Series 3 02-12-2014 04:10 PM
battery group size? tigman_tim 1999 to 2016 Super Duty 6 01-05-2014 02:31 PM
Battery Recommendations Freaksh0w 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 02-19-2010 06:13 PM
Tags
96, alternator, bad, battery, f250, ford, kills, magnatized, magnetized, magnitised, post, pulley, sears, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
