2002 Explorer Amp Installation - Ford Truck Enthusiasts Forums
Old 12-13-2004, 04:29 PM
mwarren mwarren is offline
mwarren is starting off with a positive reputation.
Talking 2002 Explorer Amp Installation
Hello,
I'm trying to install a power amp to push some subs. But I can't seem to find a place in the fire wall to run power. Can anyone help me! Also, it would be great if some could tell me which of the 8 wires running into my back doors, (4-door), are going to the speakers, thus I'd know which ones to tap into for a signal.
Thank you!
Mike
Old 12-13-2004, 04:38 PM
Muffinman Muffinman is offline
Muffinman is starting off with a positive reputation.
Try pulling the carpet back by the brake pedal. If yours is a automatic then there will be 2 places where the standard would have came threw. Just use a small hammer and punch to knock it out. Also please install a bushing in the hole before you run your wires in, You will thank yourself for it.
Old 12-13-2004, 04:42 PM
Smile 2002 Explorer Amp Installation
Thank you! I'll try it tonite. That was my biggest problem. Thanks again.
Old 12-14-2004, 08:20 AM
OK I didn't get a chance to look at that. However, I'm still wondering about the speaker wire in the side colums. This would enable me to put my door frames back together and thus end the "ding, ding, ding" because my seat belt isn't "clicked".
Old 12-14-2004, 04:10 PM
rangerxlt02's Avatar
rangerxlt02 rangerxlt02 is offline
rangerxlt02 is starting off with a positive reputation.
When you say you're going to tap into the factory wires for a signal, a signal for what exactly?
Are you going to use those wires to feed to an amp for the subs?
I'd suggest run your own wiring for anything outside of the stock setup.
Big 3 & amp power skidmarks82 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 01-23-2017 11:32 PM
2012 Illuminated Running Board Courtesy Light wiring TerraTug 1999 to 2016 Super Duty 21 10-22-2016 01:48 PM
How to upgrade the stock sound on an Aerostar KhanTyranitar Aerostar 51 03-23-2015 07:51 PM
Parasitic load Macrosill 6.0L Power Stroke Diesel 4 03-20-2015 02:00 PM
Should I Bypass My Factory Amp? SeannyBoy84 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 10-06-2006 10:17 PM
Tags
02, 2002, amp, amplifier, easily, explorer, ford, install, installation, mount, mountaineer, place, radio, speakers, subwoofer, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
