275 70 18 is equivelant to what 32 or 33 " - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-13-2004, 11:14 AM
14u2nv 14u2nv is offline
14u2nv is starting off with a positive reputation.
275 70 18 what is the american size 32 or 33"
Old 12-13-2004, 11:22 AM
industrialjunk industrialjunk is offline
industrialjunk is starting off with a positive reputation.
33.15"
Try this link bottom of page= http://www.bncoffroad.com/tire_gear_cal.html
Old 12-13-2004, 11:40 AM
thank you very much
Old 12-13-2004, 12:54 PM
Daryl Hunter's Avatar
Daryl Hunter Daryl Hunter is offline
Daryl Hunter is gaining momentum as a positive member of FTE.
The general formula formula for tire diameter given the www/hhRrr info is:
((2 x www x .hh) / 25.4) + rr
Where www is the tread width, hh is the height%, rr is the rim diameter, and 25.4 does the mm to inches conversion.
So 275/70R18 would work out to:
((2 x 275 x .70) / 25.4) + 18 = 33.16 inches.
This is the typical height as measured on the appropriate rim. For example most tire mfrs quote the diameter of the 265/75/R16 tire using a 7.5" rim and many users are putting the tire on 7" rims. This causes the tire to crown a bit and increases the tire diameter a bit.
Finally, the effective diameter of the tire rolling down the road is somewhat less than the value given above because the tire won't be perfectly round with a load on it.
The spec sheet from the mfr usually lists the turns per mile as well as the tire diameter. The turns per mile will give you the circumference to use in gearing and mileage calculations and you can get the effective rolling diameter from that.
Daryl
1" taller tires - does the truck need to be reprogrammed? Turbo Dog 2009 - 2014 F150 6 07-07-2015 09:36 AM
Firestone Destination MT wildcat99 2004 - 2008 F150 6 12-11-2009 10:59 PM
Nitto Terra Grapplers LT275/70/18 or LT295/70/18 Fit stock? Jbru167 Excursion - King of SUVs 1 09-24-2009 08:52 AM
tire size 2006 psd fx4 2006psdCREWCABfx4 1999 to 2016 Super Duty 6 07-27-2007 07:19 AM
275 70r 18 VS 275 65r 18 whododat Brakes, Steering, Suspension, Tires, & Wheels 5 07-16-2006 05:42 PM
Tags
18, 275, 27570, 2757018, 27570r18, 275x70, 33, 70, circumference, conversion, height, inches, mm, rolling, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
