Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-12-2004, 10:39 AM
skeleton33 skeleton33 is offline
Garage is empty, add now
skeleton33 is starting off with a positive reputation.
Engine Vacuum
In a flathead 8ba, what is the amount of engine vacuum available? I'm trying to determine if I can use a power booster with disc brakes.
  #2 (permalink)
Old 12-14-2004, 07:21 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
I was thinking about this the other day. Is there any if the vehicle isn't moving? Cause the only thing I know creating a vacuum is the downdraft tube. Anyone put on an exhaust vacuum system on one of these? This is a good question.
Clayton
__________________
forum guidelines
  #3 (permalink)
Old 12-14-2004, 10:56 PM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is offline
Overkill-F1 is starting off with a positive reputation.
A flathead will have a normal amount of vaccuum 10-20 inches mercury (driving/idle) as measured at intake manifold. I don't see any problem using your brake booster. ...Terry
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
  #4 (permalink)
Old 12-17-2004, 11:52 AM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
My truck has a 8BA + brake booster fitted
runs fine
Stephen
  #5 (permalink)
Old 01-25-2005, 12:35 PM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
The term "engine vacuum" refers to the difference between outside atmospheric pressure and the amount of vacuum present in the intake manifold. The pistons in the engine serve as suction pumps that create this pressure difference.
Normal Engine Operation: At idling speed, an engine at sea level should show a steady vacuum reading between 14 in. and 22 in. Hg. A quick opening and closing of the throttle should cause the vacuum to drop below 5 in., then rebound to 23 in. or more.
Find a vacuum port on your carburetor or intake manifold and check to insure that you have steady vacuum at the stated levels. If so, your vacuum brake booster will operate properly.
If the vacuum is not steady, the gauge needle behavior tells a story of engine condition. There are charts available to interpret your gauge readings.
__________________
SteV8e
1952 F3
Put this in your signature if you are a Christian with an Effie!
Tags
8ba, booster, boss, brake, carburetor, draft, drops, engines, flathead, ford, power, pressed, truck, vaccum, vacumn, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
