speedometer reads high - Ford Truck Enthusiasts Forums
Old 12-12-2004, 10:45 AM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
The speedometer in my 79 F-150 reads about 5 mph high. I've got 3.50 gears and 235-75R15 tires on it, with a 17 tooth speedometer gear. A buddy has a truck configured identically, with a 17 tooth gear, that reads right on. I've tried all of my spare instrument clusters in it, and they all read the same, so it's not a worn out speedometer head. The cable looks to be in good shape too. Any ideas? The 17 tooth gear has to be the right one?
Old 12-12-2004, 10:53 AM
BillNYS BillNYS is offline
BillNYS is starting off with a positive reputation.
Are you sure he has the same gear? Are the tires the same circumference?
Old 12-12-2004, 12:13 PM
I guess I'm 95% sure he has 3.50's. Yes the tires are the same. Can anyone with this tire/gear combo tell me what speedo gear you have?
Old 12-12-2004, 04:22 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
You might try an 18 tooth gear.
Old 12-12-2004, 09:17 PM
michaelbarry's Avatar
michaelbarry michaelbarry is offline
michaelbarry is starting off with a positive reputation.
are you sure yours is reading high,maybe your friends is reading low?...
Old 12-12-2004, 09:31 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
The output shaft in the transmission may have a different gear.
Check your speedo against 5-10 mile markers on the road or at one of those "Your speed is" setups that the police place along the road. Timing how long it takes to go one mile is not accurate enuf.
Speedometers in the USA are set up to read 1000 revolutions of the speedo cable per mile. You can tell that you have a bad speedo head if the odometer is correct but the speed is off. Always check the odometer over at least 10 miles.
Old 12-12-2004, 11:14 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
My 78 I had to change the tranmission a year ago and the trans I put in now reads that I'm doing 15mph faster. Took it to the tranny shops and they put in a 19 gear and it still is out. The ckuster and cable and gaer are good. They say the splines that the gear matts onto in probally wore and needs to be replaced. This would require them to tear the trans tailshaft apart to replace the splines on the output shaft thatthe speedo operates from.
So I have not done this. So on the highway my speedo says I'm doing nearly 80 and I'm actually doing 60. For now I'm leaving it that way.
Old 12-12-2004, 11:25 PM
culiv culiv is offline
culiv is starting off with a positive reputation.
If there is any highway construction in your area, they sometimes put out the radar displays to show how fast the traffic is running. If you can find one of these, run thru it at 30, 55, 60, 70 (or speeds you will typically drive) mph displayed and see what your speedo shows. As long as you remember what the indicated speed is for the desired actual speed, you won't have a problem. This is the cheap way to resolve the problem. At 60 actual, my speedo shows 65-66. The 10 percent error here decreases as my speed drops. At 32-33 indicated I'm actually running 30.
Old 12-13-2004, 04:39 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
I've got 235/70-15's with 3.25 rear gears and a 4-spd manual OD tranny (8 teeth on the output shaft) and I run a 19 tooth driven gear. My speedometer reads about 61 mph at a true 60 mph.
To calculate the correct number of teeth on the driven gear for your combo:
(Drive gear teeth X Ring & Pinion ratio X Tire Revs per mile) / 1000
New 235/75-15's should turn about 720 revs per mile and if you have an 8 tooth drive gear, your driven gear should be about (8 X 3.5 X 720) / 1000 = 20.2 so I'd try a 20-tooth driven gear.
I'd first try and verify the number of (drive) teeth on the tranny output shaft. Unhook the speedo cable at the cluster and attach a masking tape flag to it. Then jack up the rear wheels, put a chalk mark on the drive shaft, and make exactly 10 revolutions of the driveshaft while your assistant counts the number of revs of the flag on the speedo cable. The number of drive teeth would be the number of driven teeth X 10 (or 170) divided by the number of revs of the speedocable. (Say your speedo made 18 3/4 revs for 10 revs of the driveshaft, then the number of drive teeth would be the number of driven teeth (17) X 10 (which would be 170) divided by 18.75, or 9.066, so you would then have 9 drive teeth).
Hope this is clearer than mud
Old 12-17-2004, 10:28 PM
Thanks guys. I am positive it is off; when it reads 70 I know for a fact I'm only doing 65.
I have my transfer case tore apart right now, and from what I can tell I have a 7 tooth drive gear. Using the above formula, I come up with 17.64. My tires are far from new, so an 18 tooth would be about perfect. Thanks a lot pdqford! You did a lot of thinking for me there. I didn't realize there were different drive gears also.
Speedometer help Scrpmny 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-23-2015 06:19 PM
After engine and tranny swap speedometer is way off sleddog60 1967 - 1972 F-100 & Larger F-Series Trucks 8 09-24-2014 12:02 AM
Speedo Driven Gear Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 07-10-2014 08:35 PM
Which driven gear do I need? big-ugly 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-15-2014 02:50 PM
BW 1345 speedo revs/mile, calculating speedo gears ericconn Clutch, Transmission, Differential, Axle & Transfer Case 0 07-13-2013 05:33 PM
Tags
0279, 066, 15mph, 1966, 2007, cluter, f150, fast, intrument, mustang, reading, speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
