Changing '02 Explorer Power Steering Fluid - Ford Truck Enthusiasts Forums
Old 12-10-2004, 08:27 AM
bradcdavis00 bradcdavis00 is offline
bradcdavis00 is starting off with a positive reputation.
My Ford Dealer told me that I need to change the power steering fluid on my 02 Explorer. He said it wasn't bright red anymore and recommend spending $110 to flush and refill the system. I said "no" because I've never had to replace the fluid in any of my cars. It isn't even in the manual as a maintenance item. I got it home and began thinking it couldn't hurt anything to change it every few years or so.
Does anyone know the proper procedure to change the power steering fluid?
Old 12-10-2004, 11:09 PM
c96drumm's Avatar
c96drumm c96drumm is offline
c96drumm is starting off with a positive reputation.
Never heard of a procedure for that. Maybe you could empty the reservoir with a turkey baster and refill a few times with some driving in between? I'm thinking about doing that with my wife's Windstar because the PS fluid doesn't look all that great. Not as good as a complete drain and refill, but alot better than nothing.
Old 12-13-2004, 10:24 AM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
That's the way I do it. This way dosn't give a full transfer of fluid, but it keeps the possible leaks (from removing hoses) to a mimimum.
Power steering leak minnesotafisherman 1987 - 1996 F150 & Larger F-Series Trucks 17 11-19-2011 01:29 AM
Quest. about Power steering fluid 5.8F250 Explorer, Sport Trac, Mountaineer & Aviator 6 05-11-2011 05:30 PM
Power Steering Fluid for 02 F350??? pilot4x41 1999 to 2016 Super Duty 2 02-11-2007 11:05 AM
What's the difference between Type F ATF and Power steering fluid puck1263 Oil & Lubrication 13 04-13-2006 12:50 AM
power steering fluid change MJW 1999 - 2003 7.3L Power Stroke Diesel 2 03-26-2004 10:17 AM
Tags
02, 2002, 2004, change, changing, exploreer, explorer, fluid, ford, forums, location, power, stearing, steering, stering, steringfluid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
