ABS Light on 2001 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-19-2001, 05:36 PM
Pranksters Pranksters is offline
Pranksters is starting off with a positive reputation.
When my turn my fog lights on after a cold start, they started to flicker for some time, when they flicker off the BS light would come on and off. After truck warms up just the ABS flicker on and off any ideas?
Thanks
Old 06-19-2001, 07:40 PM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
Yeah, If its a 2001 I would assume it is still under warranty. Take it back to the dealer and tell them to fix it.
People who say it can't be done should not interrupt the person doing it.
Old 06-20-2001, 08:43 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Flickering indidates a small short in the system or a bad switch/relay. It'll be a tough nut to crack ---- tracking down shorts is time consuming....
Ken Payne
Ford Truck Enthusiasts Admin
Old 06-20-2001, 03:43 PM
Kpayne: Thanks for the reply. Does this short cause any driving problems since I am unable to get to the garage for the next couple of weeks?
THanks
Old 06-20-2001, 07:36 PM
hotrodpinto hotrodpinto is offline
hotrodpinto is starting off with a positive reputation.
Take the truck to the dealership and tell them to fix it under the factory warranty. We had a similar problem with the 2001 Ranger we have at work. The light started flashing intermittently at first, and then stayed on whenever the engine was running. Didn't notice any driveabilty problems, though. We took it to the dealer, and found out a wire going into the clock spring was shorting out. Hasn't come on since then.
Old 06-23-2001, 09:48 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
Old 06-24-2001, 09:41 AM
masonbcaldwell masonbcaldwell is offline
masonbcaldwell is starting off with a positive reputation.
The problem you describe could be a faulty ground circuit. I am an industrial service tech and have seen a similar problem in older relay logic machines. When the ground or return circuit is broken then then the power will sometimes find another path to ground. When that new path is thru a relay coil the circuit will oscillate. In your case it flickers which could be the same type of oscillation.
Mason
"charge" light flicker issue 1981fordstepside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-21-2014 01:11 PM
headlights flickering 300sixnick 1973 - 1979 F-100 & Larger F-Series Trucks 30 01-21-2014 11:06 AM
Flickering head lights IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 01-08-2014 10:58 PM
battery light flicker?? 036.0stroke 6.0L Power Stroke Diesel 4 09-25-2013 10:07 PM
Flickering Lights JustDriveTwo 1987 - 1996 F150 & Larger F-Series Trucks 6 09-16-2011 10:57 PM
Tags
2001, 5r55e, abs, fix, flashing, ford, light, lignt, ranger, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
