Ford F4
Old 12-09-2004, 11:15 AM
f4indy's Avatar
f4indy
f4indy is offline
Ford F4
I am thinking about purchasing a '49 F4. I've owned a 66 F-100 before. I know that the F4 is a totally different truck but I've always wanted to own this vintage. What do I need to know before purchasing? Will parts be harder to find than on the '66? What about the non-synchro gear box and powertrain? (Never owned a flat-head). I also nothing about the oil system on these? I understand that they use a not-detergent oil. Are body panels obsolete? What should I know about this truck?
Any information that you can provide me with is greatly appreciated. Thanks, Scott
Old 12-10-2004, 07:15 PM
f4fran's Avatar
f4fran
f4fran is offline
Welcome to the site Scott. F4 and larger trucks use a unique wheel bolt pattern. 5 lugs on 8 inch diameter. Aftermarket replacement wheels are all but impossible to find. The F4 came standard with dual rear wheels with 18" diameters. Tire types are limited, and found at Coker, etc. The optional SRW F4 had 20" wheels, with slightly more availability. The F5 & 6 only had 20" DRW. Brake parts for the bigger trucks can (hopefully) be found at Job Lot Auto in NY.
Fran
Old 12-13-2004, 07:21 PM
f4indy's Avatar
f4indy
f4indy is offline
Thanks for responding, Fran.
IHdieselfan
11-30-2011 05:01 PM
Scifi266
11-05-2011 08:06 PM
ford66
11-09-2010 12:10 AM
37 Ford guy
1961 - 1963 F100 Unibody
04-06-2009 07:39 PM
JohnT
12-16-2005 03:09 PM
Quick Reply: Ford F4
