Aluminum Floor Jack
I have the Craftsman unit; the full alum one. Great for the track. By placing a 4x4 block on the pad the truck can be lifted. At 42lbs I my never use the old steel unit again. I saw one on Two Guy's Garage today for $600!!!!
http://www.sears.com/sr/javasr/produ...id=00950239000
My wife bought me one at Costco. I love it! I've used it several times and was impressed. I only lifted small cars, don't know if I would trust it to pick up anything heavier than a car. It is rated @ 3000Lb. I also went to Harbor Freight and purchased two Aluminum jack stands. Will have to see how they work.
I think the failure rate of the harbourfreight jacks is pretty high. They are everywhere in club racing these days, so much so that people wrap colored tape around the handles to distingush one from the other. The two complaints I have heard are a) the saddle can break if the load is not centered enough; b) they quit working mysteriously, possibly because of air in the lines. When mine quit last summer I had to drain all the oil and re-bleed it. I think it was a result of transporting on it's side...
I went into Canadian Tire last night with the idea of checking out their 21/2 Ton Service Jack and comparing it to a GEL Tools 2 1/4 ton, both at $140.00. After much grunting (80 lb. box) bringing it down and getting it back up, I figures that the GEL was a better tool for $140. Stood up and stretched and then noticesd that they had a 3 ton with two 2 Ton jack stands on for $89 on sale. Even heavier, has a speed pump handle plus the regular long handle and the jack stands are nicely made.
Gotta love it. Went back today and picked up a light one (2Ton) that came with double ended wheel nut sockets (Neat, never seen'em before), wheel chocks to stop the truck rolling and a 12 volt tire pump, all in a fitted plastic case and the works for $39.00. Remarkable prices and the quality is good enough for the hobbyk stuff that I do.
Pat
Pat
scooterspal
26
09-18-2018 07:50 PM
lortech
1999 to 2016 Super Duty
06-01-2011 12:44 PM
