Ham radio operators in Fords - Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Puddy
Old 12-08-2004, 12:57 AM
SAR Roy SAR Roy is offline
SAR Roy is starting off with a positive reputation.
Any amateur radio operators driving Fords on the list? If so, what's your call and what kind of radio(s) are you running?
I'm in a '97 F-150 4x4 longbox with an Icom IC-2720 dual bander.
73
Roy VE7IBJ
Mission, B.C.
Old 12-13-2004, 08:26 PM
bchunter's Avatar
bchunter bchunter is offline
bchunter is starting off with a positive reputation.
VE7 JFO
I have a TAD M8 right now that I have to get the local fx into, but have never got around to it. I am waiting to move to the country side before I put up a tower and have all my neighbours complain.
93 F250 4X4 reg cab, long box, 7.3 IDI with a ton of mods
Smithers, B.C.
Old 12-13-2004, 11:26 PM
Haven't been to Smithers in 20 years. Drove there and then flew out when I worked for Conair. Lovely area. Did make it to Terrace to work the airshow this year. Farthest north in BC this season.
73 de Roy
Old 12-15-2004, 10:40 AM
bchunter's Avatar
I am a little biased but I have to say that I like Smithers better the Terrace
Old 10-26-2005, 01:53 AM
dermeister dermeister is offline
dermeister is starting off with a positive reputation.
So i'm a bit late posting to this thread... My call's VE7EDQ, and i have a TM-D700 residing in my '94 F-150 S/C 4x4... damn good radio, had it underwater once when i took my truck somewhere it really shouldn't have been... but i killed the power in time, just had to wash out the 1/8 inch of silt, change a switch, and redo a couple solder joints and it was back on the air! I also pack a Yaesu FT-60 handie to run the local ham and SAR repeaters.
The predecessor to the Kenwood was actually a Tad M8 - they're solid radios too.
Old 10-31-2005, 12:23 AM
bchunter's Avatar
Bounced mine in my diesel for 3 years and never had a prob. Now it is in my 150 and the ride is alot smoother so I doubt I will have any probs after the diesel.
Still haven't got the local frequencies and still haven't moved to the countryside. I guess that is what a 5 month old will do to you
oil leak roy123 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-18-2013 07:11 PM
Fuel Pressure Regulator ford302mudder 1987 - 1996 F150 & Larger F-Series Trucks 8 04-23-2013 03:18 PM
EBP sensor confusion cps 1999 - 2003 7.3L Power Stroke Diesel 2 07-28-2012 12:29 PM
2010 Gas Mileage RoyC 2007 - 2014 Expedition & Navigator 10 05-02-2010 05:45 PM
code 512 tinman57 1987 - 1996 F150 & Larger F-Series Trucks 4 02-23-2004 01:01 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
escape, expedition, f150, ford, ham, hybrid, ic2720, radio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
