93 Ranger runs rough, EEC codes 335, 326 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-23-2001, 01:39 PM
tstrickland tstrickland is offline
tstrickland is starting off with a positive reputation.
My 1993 3.0L V6 2WD Ranger is running rough on the road, but not too bad at idle. I first thought it was related to the transmission because I recently had a Torque Converter lock-up (diagnosed by Ford) that mysteriously fixed itself before they could determine the root cause. But I checked the EEC codes yesterday and got a KOEO 335 (EGR feedback signal out of range) and a KOER 326 (Pressure Feedback EGR shows low pressure EGR not seating). Will an EGR problem cause the vehicle to run rough? Should I take the shotgun approach and replace the EGR valve, or are there additional diagnostic steps I should take? Could this be a problem with the EGR Vacuum Regulator as well, or the PCM?
I have never tried to trouble-shoot an EGR system, so any practical advice would be appreciated. I do have the Haynes Repair Manual for 1993-2000 Ranger pick-ups.
thanks.
Old 08-24-2001, 10:30 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
I would try removing the EGR valve and cleaning the pintle area out before starting to replace parts. The EGR's tend to get clogged up with carbon and then start sticking. Also check the EGR valve for a ruptured diaphram. You can simply suck on the vacuum hose going to it and see if it will hold vacuum. Also check all of the vacuum lines going from the EGR to the engine, for a leak.
Good luck.
Old 08-24-2001, 10:35 PM
EGR pressure feedback trouble maniac2025 1997 - 2003 F150 9 08-15-2011 09:06 PM
Code 335 (KOEO): DPFE Voltage too high. Do I care? bbass408 Ranger & B-Series 2 04-27-2009 09:32 PM
94 b4000 cel on constant 335 code mzdb4000 Ranger & B-Series 6 02-03-2008 01:50 PM
86 Ranger 2.9 L-Rough, Rich Idle and Code 33 issues bluestreak1979 Ranger & B-Series 5 08-21-2006 09:48 PM
Code 556 ... anyone? joelb Explorer, Sport Trac, Mountaineer & Aviator 4 07-17-2002 07:39 PM
Tags
1993, 1994, 2003, 30, 335, 93, code, egr, feedback, ford, iswas, poor, range, ranger, rough, running, runs, signal, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
