Aerostar Ford Aerostar
Backup lights test?
Old 12-06-2004, 04:36 PM
NorthernStar's Avatar
NorthernStar
NorthernStar is offline
Backup lights test?
My backup ligths are not working. Dead.
Where is the switch and how do I test it?
-90 3.0L Extended, A4LD
Old 12-06-2004, 04:42 PM
M.Herrington's Avatar
M.Herrington
M.Herrington is offline
How The Circuit Works
With the Ignition Switch in RUN, battery voltage from Fuse 5 is applied to the Backup Lamp Switch (manual transmission) or Park/Neutral Position Switch (automatic transmission). When the transmission is shifted into reverse, the Backup Lamp Switch (manual transmission) or Park/Neutral Position Switch (automatic transmission) closes, and battery voltage is applied through the 140 (BK/PK) wires to both the Right and Left Backup Lamps. Both lamps are grounded through the 57 (BK) wires to ground G101.
REFERENCE :For diagnostic information, refer to «Section 17-01 » of the Service Manual.
HAMMERDOWN103
03-27-2014 02:16 PM
73FOMO
12-28-2011 01:59 PM
catman700
2004 - 2008 F150
05-19-2008 09:58 PM
79CEEJAY
1999 to 2016 Super Duty
18
11-24-2002 11:50 AM
RandysF150
10-01-2002 11:48 PM
Quick Reply: Backup lights test?
