ride quality of 8"+ lifts??
I have a 8.5" lift (4" springs and 4.5" hanger and shackle) and I think it rides pretty good for a lifted truck. Only things I've done to effect the ride is adjust tire pressure and order up DR Signature Series 2.0" reservoir shocks.
I agree that tire pressure and tires will effect the ride.
I have the same question as Yeti, what brand of shocks are you going with?
Have you thought about going with crossover steering and trac bar relocation? I have it on my 8.5" lift and I definately would recommend it, especially with a 10" lift.
the shocks the salesmen might sell me are the new procomp reservoirs...he said their basically the edelbrock reservoirs in a different packaging. Theyre significantly les expesive, since I need eight of them!! This build is pretty much for a show and tell driver...not really gonna be "off-road" too much...did I mention its a dually??? The tire issue is another headache...Im probablly going to go with the 38.5 IROKs since theyre 10 ply. Ill live with the pizza cutters in the front for now. I have a few things that Im getting cromed. The trucks all black..so itll look pretty sick!! Anyway, Ill see what the superlift springs are like at first, and go from there. How can you tell if the shocks are valved for your specific truck??
I don't know jack about the Pro Comp reservoirs.
You'd have to ask what the valving is or if they are valved specifically for the SD.
Why do you "need" eight shocks?
Really you only need four, IMO. Additional shocks "look cool" but if depending on the valving it may make the ride too stiff for some.
How much are the Pro Comp reservoirs??
Why do I need eight shocks??? Its kinda like asking why do we need a big as truck to drive around when a little honda would be ok...because we want to right??!! and itll look good...again, this is more of show and tell truck than a work horse. I believe the shocks are 4 for just under $400.00 They just came out and their on a two week back order.
Originally Posted by 02superstroker
The reason I ask is because four wheel parts owns pro-comp, or maybe its the other way around, im not sure. At anyrate they will push pro-comp products more than other brands... just something to keep in mind.
