04 F150 True Dual Exhaust?
Old 12-05-2004, 11:30 PM
SNEAKY F350's Avatar
SNEAKY F350
SNEAKY F350 is offline
Question 04 F150 True Dual Exhaust?
I have a 2004 FX4 5.4L regular cab. I have been told by several people that cutting after the cats and running truse duals will produce a problem indicator light because the cats won't work properly. My exhaust guy says that he installs them all the time with no problems. Which school of thought is correct here? Anyone running true duals on this engine? Thanks.
Old 12-06-2004, 12:14 AM
Gary42141's Avatar
Gary42141
Gary42141 is offline
The converters should still work fine. The only possible problem I can see is with the O2 sensors, but I don't know why they wouldn't work the same as before.
Old 12-06-2004, 07:57 AM
MotorPsycho's Avatar
MotorPsycho
MotorPsycho is offline
I'm not yet, but I plan to. The issue with the cat backs currently available is that they bolt on where the factory muffler bolts to the factory Y coming from the cats. The factory Y has two 2 1/2" pipes joined into one 2 1/2" pipe. Bolting a 3" or dual exhaust system onto a 2 1/2" Y pipe doesn't make sense to me.
I intend to have either a 3" single or dual 2 1/2" system welded on to the factory pipes right in front of where they come together. If I get a dual system, I'll get them both run down the passenger side of the truck and out the passenger side behind the rear wheel. The drivers side of the truck is blocked by the gas tank. Also, I don't want rear exit duals because I regularly tow things I'm fairly fond of.
The only issue I haven't researched is whether there are any O2 sensors attached in the section of exhaust I intend to have disgarded. If so, I'll have the muffler shop include them in the new system.
As long as you don't eliminate any of the factory O2 sensors, you shouldn't have a problem.
Enjoy.
Old 12-06-2004, 08:27 PM
BroncoBoy347's Avatar
BroncoBoy347
BroncoBoy347 is offline
I have true duals on mine and have never had any engine light come on and it runs and sounds great
Old 12-07-2004, 08:14 PM
Hambone555's Avatar
Hambone555
Hambone555 is offline
me too... I have true dual, with no problems. Sounds great.. No lights.
Old 12-24-2004, 09:17 PM
superfx4's Avatar
superfx4
superfx4 is offline
I had 3" dual exhaust put on with no problems.
Old 12-24-2004, 09:22 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Welcome to the only family Ford Truck site, on the net. To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE
2000f1505.4
1997 - 2003 F150
02-14-2012 10:05 PM
2002exPSD
20
02-11-2011 03:50 PM
papajoemrt
Exhaust Systems
23
11-13-2007 10:25 PM
03_FX4
Exhaust Systems
09-06-2007 03:05 PM
RyanJake
10-23-2005 09:13 PM
Quick Reply: 04 F150 True Dual Exhaust?
